Author Topic: Junk Yard OD Tranny Does it fit a 318-340-360  (Read 3186 times)
Offline ShelbyDogg
« on: March 22, 2006 - 10:25:35 PM »
So this junk yard here has 2 complete 91 and 92 dodge truck trannys laying on the ground with converters and wants $60 for them?  Are these the 518s that I never could afford new? It looks exactly like a 727 with an overdrive bolted to the tail end and a perfect addition to another Challenger that I'm building.  Does it fit a small block?  And where do I find a diagram for the extra wires that I assume are for a lockup clutch?
Offline MyMopar
Re: Junk Yard OD Tranny Does it fit a 318-340-360
« Reply #1 on: March 23, 2006 - 08:34:55 AM »
You might be looking at a 4x4 727 w/transfer case bolted to it or something as the overdrive is part of the transmission and not an added on unit as you described.  Perhaps I misunderstood what you typed  "It looks exactly like a 727 with an overdrive bolted to the tail end" but that sounds like a 4x4 tranny.
Here is a picture, but you can do a goolge search and find some to compare to yourself.  I belive that they will bolt up but do require some fabrication.
4wd
2wd
« Last Edit: March 23, 2006 - 08:38:06 AM by MyMopar »
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Offline ShelbyDogg
« Reply #2 on: March 23, 2006 - 06:12:27 PM »
Thanks! that bottom one is it!   I can make a rear mount to fit it in a Challenger. I've put 440s in Plymouth Arrows and Dodge Daytonas. so a rear mount is nothing.  Does anyone here have one of these in a e-body already?
Offline MyMopar
« Reply #3 on: March 24, 2006 - 08:45:21 AM »
From looking through past posts, it looks like a few people have done the conversion.  Some have transplanted the entire engine/trans combo and went the efi route and used the computer and harness from the donor vehicle.
I might go that route one day when wrecked Hemi Magnums, Chagnums and 300C are plentiful.  Hopefully the 6.1 hemi.
Offline rallyechall
« Reply #4 on: March 24, 2006 - 09:32:55 AM »
There were 2 types of OD 518s. One is hydraulically controlled, and one is electronically controlled. The hydraulic type is preferred. You want to look for the 46RH for hydraulic, or 46RE for electronic.
Offline Stacked440
« Reply #5 on: March 28, 2006 - 05:03:30 PM »
My 79' International Scout II has a 4x4 727 in it, didnt know there were 2 different kinds. looks just like the top picture
-Kyle-
Offline rallyechall
« Reply #6 on: March 29, 2006 - 06:05:54 AM »
there are 2 different styles of 518s. The preference is the hydraulic, but you can buy the necessary parts for the electronic version.
Here is one place.
http://www.rostra.com/transmissions.htm
Great how-to here.
http://www.transmissioncenter.net/727Transmission.htm
Offline ShelbyDogg
« Reply #7 on: March 29, 2006 - 12:34:41 PM »
Thanks for those great links!
« Reply #8 on: March 29, 2006 - 09:43:59 PM »
yuo wil have to modify the trans mount/ T bar cross member to gain extra clearance to get the tranny in at the correct angle
Offline tactransman
« Reply #9 on: April 14, 2006 - 02:34:16 PM »
Both the 46RH and the 46RE are electronic.
The 46RH  1st 2nd and 3rd are hydraulic no eletrical needed but OD is electric, you will need a switch for OD and a switch for Lock-up if so equipped.
A lock-up style 46RH will have a smooth pilot on the tip of the input shaft and three wires going to the OD/LU connector (middle wire is 12 volts, outer wires are grounds for LU and OD solenoids)
Non lock-up will have two wires on same connector.(above neutral safety switch).
Non lock-up can use a 727 stall converter. :jumping:
The 46RE is totally electonic requiring a computer to shift (1996 -on) all are lock-ups . :)
Terry-tactransman
Union, Mo.
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #10 on: June 21, 2006 - 04:16:53 PM »
this is the best link/description I've found on the web about swapping the 727 to a 518.  They have all the parts you need and can put together a Kit for you.
Scroll down the page for the description.  Very Cool!
PlumCrazyChris
Austin, Tx
70 Challenger 340 Convertible
70 Challenger 340
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
« Reply #11 on: June 21, 2006 - 04:23:38 PM »
PlumCrazyChris
Austin, Tx
70 Challenger 340
Chris,
  You forgot the link.  :grinyes:
  Mike   :wave:
Offline tactransman
« Reply #12 on: June 21, 2006 - 04:38:34 PM »
I think he is talking about the transmisssion center link above.
Terry-tactransman
Union, Mo.
« Reply #13 on: June 21, 2006 - 05:16:40 PM »
   :lol:  :lol:  :lol:
  Well, that wouldn't be my first mistake today. Who knew "link" meant so many things?  :bricks1:
