Author Topic: Radiator fluid dripping off spark plug???????  (Read 2384 times)
Offline Cuda Cody
  • Vancouver, WA
« on: March 23, 2006 - 11:58:08 PM »
Can anyone tell me why I have radiator fluid dripping off the spark plugs?  Both sides!
Offline Cuda Cody
  • Vancouver, WA
Re: Radiator fluid dripping off spark plug???????
« Reply #1 on: March 23, 2006 - 11:58:34 PM »
it's a 383
Offline Killer_Mopar
« Reply #2 on: March 24, 2006 - 12:28:11 AM »
It looks like the header bolts are the culprit. The exhaust bolts go into the waterjackets and sometimes leak, reseal them and you should be fine.
Offline Cuda Cody
  • Vancouver, WA
« Reply #3 on: March 24, 2006 - 12:33:03 AM »
You the man!  Thanks! :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
« Reply #4 on: March 24, 2006 - 02:39:57 AM »
  Either the bolts are loose, or someone didn't put sealant on them when they installed the headers.
Offline Hemi Challenger
  • Nothing run better then a HEMI
« Reply #5 on: March 24, 2006 - 04:52:13 AM »
or it could be the intake bolt not sure unless I check it myself but that would be hard to do since I'm in Maine and he is in other state
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
« Reply #6 on: March 24, 2006 - 06:27:11 AM »
Hey Mike, I have to replace the header gaskets on mine and I didn't even think about sealant.  Do you (or anyone else) know what sealant should be used.  I'd rather have the opinion of someone here on this board who is familiar with our type cars.
« Reply #7 on: March 24, 2006 - 07:10:15 AM »
UGH,
   I'll get back to you later with what I used. Right now all I can tell you is it's a white sealant. Kind of like Elmer's glue. It comes in a small white tube with red lettering. That should narrow it.  :lol: Seriously, I'll get back to you in a few hours.  :wave:
« Reply #8 on: March 24, 2006 - 09:46:30 AM »
ROMI,
  Here's what I used. The small Permatex tube I bought at AutoZone. It's more than you'll need. The ARP sealant, I believe I bought from Summit, or Year One. Just be sure what you use says "thread sealant".
Offline ROMI
« Reply #9 on: March 24, 2006 - 11:11:22 AM »
As always, THANKS... I'll be dropping by Autozoned on the way home tonight.
 :clapping:
Oldschool
« Reply #10 on: March 24, 2006 - 01:33:54 PM »
CODY,  you have to be happy about this info.  Good to know there is nothing major wrong.  Easy thing to fix.    :cooldancing:    Oldschool
Offline Cuda Cody
  • Vancouver, WA
« Reply #11 on: March 24, 2006 - 03:24:30 PM »
Yes! ... and well there are still several other items I must fix....
~Blinkers don't work.
~The radiator is leaking too.
~Transmision fluid or Power steering fluid is also leaking.
~Front left light bulb needs replaced
~no spare wheel (gotta find one now)
~No heat or even the plumbing for it
~speedo needs to be calibrated (11mph off at 50mph)
~Altenator is working, but makes noise so it will be replaed (Scott sent an extra one)
~Radio doesn't work
~No SEAT BELTS! (if anyone has an extra set I would VERY much like to buy them!)
and one thing that must be fixed right away.  The car won't stay running... I think it's just a simple carb adjustment. :working:
Overall I'm happy with the car.  It just needs some time & money put in to it.  In hindsight with what it needs I don't think I buy it again, but it's mine now and I'll fix all the little issues and LOVE it!  You guys are more valuable than a you can imagine.  If this site ever needs some help with funding, please let me know.  This is the best site on the web! :bigsmile:
Oldschool
« Reply #12 on: March 24, 2006 - 04:14:12 PM »
Cody---this link might help with the speedo re-calibration.
http://www.forabodiesonly.com/mopar/showthread.php?s=&threadid=6978
Oldschool
Offline Cuda Cody
  • Vancouver, WA
« Reply #13 on: March 24, 2006 - 04:26:42 PM »
Knowledge is power!  Thank you!
Great link.
Oldschool
Offline ShelbyDogg
« Reply #14 on: March 30, 2006 - 10:20:02 AM »
Cody,  I forgot to tell you when I was on the phone Monday:
Drain the coolant a little so the level is below the header bolts.
Pull out a leaking header bolt.
Spray the bolt and head threads with brake cleaner, allow to dry, coat with a little hi-temp silicone sealer, thread bolt back in.
Move to the next bolt.
No more leaks.
