Author Topic: Tire Size???  (Read 6582 times)
Offline Sublime1970
Tire Size???
« on: March 24, 2006 - 06:55:18 PM »
I just got 2 new 15x8 rallye rims for the rear of my 70 Challenger, will BFG 295-60-15's fit the rear of the car???? Any info or tire size suggestions will be appreciated.
Offline Cuda Cody
  • Vancouver, WA
Re: Tire Size???
« Reply #1 on: March 24, 2006 - 07:19:26 PM »
Sorry... I don't know about the wheels, but nice car!
Offline EVIL72
Re: Tire Size???
« Reply #2 on: March 24, 2006 - 07:41:15 PM »
 What's the backspacing? Do you mean 295/50/15's?
 If the backspacings 4" or 4.5" they should fit. If your leaf springs are real saggy you might want to replace them though.
 I have 295/50/15's on mine and I love the look, very meaty.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline Sublime1970
Re: Tire Size???
« Reply #3 on: March 24, 2006 - 08:33:19 PM »
yeah i have 295/60/R15's  :ylsuper: not sure the backspacing but by the looks of your car mine needs some serious leaf springs.  Thanks for the info.
Offline EVIL72
Re: Tire Size???
« Reply #4 on: March 24, 2006 - 09:16:14 PM »
 What's the specs on the 295/60/R15's? Not sure if that one will fit. I thought you ment 295/50/15's, Man that's got to be a tall tire.
ROB
Offline ShelbyDogg
Re: Tire Size???
« Reply #5 on: March 24, 2006 - 10:38:59 PM »
275/60/15 on 8" ralleys, 4.5 backspacing, no rubbing, no jacked up look.
BFGoodrich doesn't show a 295/60/15 so here are the specs on a 295/50/15 compared to my 275/60/15. My tires are close at the inner fender to side wall, but don't rub.
275/60/15
Tread Width (in): 8.90 in.
Tire Diameter (in): 28.00 in.
Section Width (in): 11.00 in.
Recommended Rim Width: 7.5-9.5 in.
295/50/15
Tread Width (in): 9.50 in.
Tire Diameter (in): 26.70 in.
Section Width (in): 12.20 in.
Recommended Rim Width: 8-10 in
That wider section width will get you into trouble.
I have a feeling that you wont be happy with the size that you want. So get my size and you'll thank me later.
Offline Grancoupe
Re: Tire Size???
« Reply #6 on: March 25, 2006 - 07:56:56 AM »
The most I've been able to jam into my car is 275/60/15. Just fits. Had to trin the inner lip of the quarter panel.
Offline Plum6Pak
  • Plum6Pak
Re: Tire Size???
« Reply #7 on: March 25, 2006 - 08:17:46 AM »
We've talked about this on other threads and there is a lot of discussion on this subject. First off, I wouldn't want to start cutting metal to get my tires to fit unless I was tubbing it or something. A little trimming doesn't hurt I guess but if it's a numbers car, I wouldn't do it. Here's a good recipe if you want the most room with no fear of rubbing.
http://www.cuda-challenger.com/cc/index.php?topic=4000.msg29615#msg29615
Offline PasiR
Re: Tire Size???
« Reply #8 on: March 25, 2006 - 01:24:56 PM »
295 is too wide for 8x15 rims. I think 255/60/15 is just perfect but if you like a "fat" look go for 275/60/15.
Offline Carlwalski
Re: Tire Size???
« Reply #9 on: March 25, 2006 - 06:09:39 PM »
275/60/15 is a great tyre IMO sits well and doesn't stick out like a sore thumb....as much as a 295.  :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline mrbill426
    • All Around Mopars
Re: Tire Size???
« Reply #10 on: March 25, 2006 - 09:12:31 PM »
275/60/15
295/50/15
They look good  :cheers:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline ShelbyDogg
Re: Tire Size???
« Reply #11 on: March 25, 2006 - 10:51:58 PM »
Thanks MrBill426,  here are the side and a rear pic showing the tread, stance and wheelwell clearance.  If you look ar the trim-ring shot, you can see the gap that a 7" trim ring shows when you put it on an 8" wheel. I wish someone made a polished trim ring fon an 8" ralley.
Offline mrbill426
    • All Around Mopars
Re: Tire Size???
« Reply #12 on: March 26, 2006 - 12:21:10 AM »
Nice fit.  :thumbsup:
How close do they come to the spring leaves?
 :working:
MOPAR or NO car!
Offline ShelbyDogg
Re: Tire Size???
« Reply #13 on: March 26, 2006 - 07:30:49 AM »
They come close but remember, the side wall never bulges on the portion closes to the spring, so it will never rub.
Offline Plum6Pak
  • Plum6Pak
Re: Tire Size???
« Reply #14 on: March 26, 2006 - 09:22:05 AM »
That looks great! Not trying to hyjack this thread but since it's on the subject. Anyone have any experience on this same subject for a B body? They sure look to have a lot of room but don't know exactly what will fit for sure. I'd like to put a set of MT DOT slicks on it but not sure what size I can stuff under there. Here's a picture of the BFG 295/50/15's. The taller and wider the better. I'd be willing to go to the offset hangers if needed.
Thanks P6P
