Author Topic: Shaker Hood Conversion - What ALL do i need?  (Read 1444 times)
Offline GoodysGotaCuda
« on: March 25, 2006 - 01:04:58 AM »
Considering doing a Shaker conversion with my flat hood.  I can get the bracing and trim ring for pretty cheap (discounted). Anyway, what ALL else is necessary?
Bubble - Whats a good driver quality bubble out there? Guessing around $200?
Grilles - Repoped? How much do those usually run.
Same question for the part that attaches at the carb
A picture of each part and how its assembled would help a lot. Any other main parts besides some nuts and bolts? Is there another ring that goes over the carb adapter plate?
Thanks
-Mike
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 4Cruizn
  • HEMI FISH
Re: Shaker Hood Conversion - What ALL do i need?
« Reply #1 on: March 25, 2006 - 08:42:49 AM »
First thing you are going to need is MONEY!!   :money:   Then I would check this site . . .
www.shakerhood.com
Offline Green Drop Top
« Reply #2 on: August 08, 2006 - 08:40:15 AM »
If you are REALLY trying to save pennies you can get industrious and build yourself a base plate and adapter ring to put under the hood and support your bubble. I wouldn't scrimp on the bubble as it's highly visable and subtle things show. Same goes for the bubble grills. The best bubble on the market is AAR fiberglasses version, or Gene Gregories, both cost about the same $300-$350.00. The grills add $250.00. Gerome Verbit makes the best grills period. Art Pacheco at Six Pack Performance in New Mexico sells Genes stuff and Geromes grills. On the super cheap you can buy plastic bubble grills on ebay for under $100.00, they work but you will notice a fit difference between them and originals.
If you want the best reproduction base plate and adapter ring those are also sold by Art Pachecho (Gene Gregories parts). Gene went further towards "correct" with the subtle details on his base plates and adapter rings like OEM appearing welds (as compared to the other source who's are incorrectly spot welded) but Art/Gene is slightly more expensive too,  bottom line? Either vendors will work but you get what you pay for. Plan on an adapter ring and base costing you around $1,200.00.
The internal hot & cold air doors and cables, etc. add to cost and are not really needed, plus you can always add them later as budget allows.
Your last choice is a fiberglass base and ring (Year One) but they don't fit really well and are still a few hundred bucks, wasted money IMO.
Good luck and happy hunting!
 :2thumbs:
