Author Topic: A little more progress  (Read 57859 times)
RedLine
Re: A little more progress
« Reply #30 on: May 30, 2006 - 07:58:26 PM »
Man, Plum6Pak-- your progress is stunning.  The colors jump out!  :thumbsup:  Top rate work!
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #31 on: May 31, 2006 - 04:14:49 PM »
WSM, your comment about looking in the rear view mirror and seeing  :bigsmile:  what about the nut behind the wheel in your car?   :grinyes:
What ya talkin bout "Willis?"  :roflsmiley: I don't know about you Glen.................but there are TWO nuts behind my sterring wheel buddy  :roflsmiley:  :roflsmiley:  :roflsmiley:  :roflsmiley:  :cheers:  :clapping:  :cooldancing:
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline Plum6Pak
  • Plum6Pak
« Reply #32 on: May 31, 2006 - 07:24:08 PM »
Only you could come up with that one! LMAO!
Offline Plum6Pak
  • Plum6Pak
« Reply #33 on: June 10, 2006 - 09:15:28 AM »
Just a little bit more progress, being out of town all the time is tough to get anything done. I installed the plugs and then spent a couple of hours installing a couple of plug wires last night.  :eek7:  Trying to come up with a nice way to route my 5-7 plug wires without them being too close to the headers and not stand out like a sore thumb.
:pullinghair:
After a while this is what I finally decided to do. Still need to figure out a couple of the others but this will work great for these two. It's 1/2" stainless tubing bent to fit and flared on the ends to avoid any rough edge touching the wires, then made a bracket and bolted it to the bell housing bolt.
« Last Edit: March 08, 2014 - 03:21:28 PM by Plum6Pak »
Offline RusTy/SE
  • Just havin' fun
« Reply #34 on: June 10, 2006 - 11:53:21 AM »
  Glen, that looks nice and clean  :thumbsup:  Nice job!!  :cheers:
Russ
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
« Reply #35 on: June 10, 2006 - 07:01:57 PM »
 :thumbsup: Most resourceful, good idea.
1970 Charger 500
1971 Dart Swinger
1973 Challenger
RedLine
« Reply #36 on: June 10, 2006 - 08:47:17 PM »
TWO (2) :thumbsup: :thumbsup:
Glen -- that looks awesome!
are the bracket and tubes insulated - or is there no cause for spark shorts
Offline Plum6Pak
  • Plum6Pak
« Reply #37 on: June 10, 2006 - 11:44:43 PM »
Thanks for the compliments, not much to brag about, when I get it as nice as most of the rides on this forum, then I may have some bragging rights!  :grinyes:
Shouldn't be any reason for shorts, if there is I have some pretty crummy plug wires. In the older days on equipment many manufacturers ran the plug wires through metal shielding and the wires back then were not as good as todays but the voltage wasn't as high either. You can actually buy a custom style plug wire holder setup made of aluminum that bolts to the rocker cover bolts, they are pretty fancy but expensive. The number 5-7-6 were the only ones I had to do this with. Got the others all installed today, hope to fire it up within a week or so. As you can see in the pictures, it needs a good cleaning!
« Last Edit: March 08, 2014 - 03:26:41 PM by Plum6Pak »
Offline Plum6Pak
  • Plum6Pak
« Reply #38 on: June 23, 2006 - 07:38:30 AM »
Got it fired up last Sunday, it was  :bigsmile: miles of smiles! Went out of town right after but will try to get a video posted soon. Sounds just like I thought it would, deep, loud and like a Mopar should but sounds a bit more radical than I expected.  :grinyes:
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #39 on: June 23, 2006 - 08:34:46 AM »
:clapping:  :cheers:  :woohoo:
« Reply #40 on: June 23, 2006 - 08:52:17 AM »
 :thumbsup:  :bananasmi
1970 Charger 500
1971 Dart Swinger
1973 Challenger
« Reply #41 on: June 23, 2006 - 07:20:23 PM »
 :woohoo: :wow: :ylsuper: Good job!!
Offline Street_Challenged73
« Reply #42 on: June 23, 2006 - 11:12:26 PM »
Awesome job, Glen!!!!!  That looks very nice tucked away in the engine bay. :drool:
Offline antilles2000
« Reply #43 on: June 23, 2006 - 11:48:41 PM »
p6p, your car looks simply outstanding!   :eek2:  i'm waiting for a burnout video.  keep pushing, because it only gets better, and guys like you keep guys like me motivated.
One step at a time...
Swedefish
« Reply #44 on: June 24, 2006 - 07:08:26 AM »
Great progress Glen, can`t wait to hear and look at her on a video   :thumbsup: :jumping:
