Author Topic: E-Body Tire Combos  (Read 608232 times)
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: E-Body Tire Combos
« Reply #1020 on: July 19, 2016 - 08:33:20 AM »
Sounds like good advice. Does that mean any non-modified E-body as well? Do you have a recommendation for a tire source for best bang for the buck?  :cheers:
Cuda's have a little more room in the rear than the Challenger but not much.  However every car is a little different too since assembling cars 45 years ago was not an exact science.  I have bought several wheels and tires from www.performanceplustire.com.  They have great prices and service delivered to your door.
Offline Aracer
« Reply #1021 on: July 20, 2016 - 03:18:03 AM »
Firestone Firehawk Wide Oval Indy 500, Firestone's Ultra High Performance Summer Tires on Year One Rallye Wheels Front 245/45R17 17"x8" 4.5" BS, Rear 275/40R17 17"x9" 4.5" BS
Both front and rear tires are 25.7" tall. W speed rating.
Zero rubs or issues front or rear.  :2thumbs:
That set of wheels is what I want. And the original style fits the car.
     Does the inside of the wheel's center bore, fit the disc or rear axle,  drum hub like a stock one?
     Also, will solid valve stems clear the rims inside edge?
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #1022 on: July 20, 2016 - 09:35:31 AM »
14" rallye wheels came off and these went on. No fitment issues at all.
Don't see why you couldn't run metal valve stems if you wanted too.
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline Mopar Mitch
« Reply #1023 on: July 20, 2016 - 11:02:27 AM »
DFRAZZ.. I think the Challengers have a bit more width/opening in the rear wheel well openings... from what I've seen.    :2cents:
Offline dfrazz
« Reply #1024 on: July 20, 2016 - 11:59:38 AM »
You could be right Mitch, either way the two cars are not exactly the same but the difference is minimal.
Offline Joe mama
« Reply #1025 on: August 13, 2016 - 11:59:54 AM »
This is a similar setup that ragtopcuda has. Year One Rallye Wheels Front 245/45R17 17"x8" 4.25" BS, Rear 275/40R17 17"x9" 5.0" BS Nitto NT555 extreme tires. W / B body Dana 60
Plenty of room in front & back.
73 Challenger, 440+6, 5 speed Tremec, Dana 60
Offline Mopar Mitch
« Reply #1026 on: August 15, 2016 - 01:31:35 PM »
Joe Mama - looks real nice.  I suggest you try the 17x9 275-40-17 up front, too.... should be AOK that size up front.
Mo Power to ya!
 :2thumbs: :2thumbs:
Offline mjb765
« Reply #1027 on: August 15, 2016 - 01:48:24 PM »
Stupid question--you can get a B Body Dana in an E body?? What kind of work needs to be done so it mounts?
Offline ShelbyDogg
« Reply #1028 on: August 15, 2016 - 02:20:49 PM »
 Same thing we all do when we put any b-body rear into an e-body. you move the springs in 1 inch with the relocation kit from Dr. Duff
Offline shawge
  • Zoiks!!
« Reply #1029 on: August 15, 2016 - 02:27:32 PM »
 :iagree: That is exactly what I did.
- Jerry
Offline mjb765
« Reply #1030 on: August 15, 2016 - 03:30:09 PM »
Thanks
Offline Joe mama
« Reply #1031 on: August 15, 2016 - 04:35:33 PM »
This places the leaf spring in farther making more room for the tires.
Offline mjb765
« Reply #1032 on: August 15, 2016 - 05:20:40 PM »
Then a stock B body rear bolts in??  Any particular year to look for and how wide a tire will fit afterwards?
Offline ShelbyDogg
« Reply #1033 on: August 15, 2016 - 07:33:51 PM »
I use 68-70 then you can use a 10" wheel with. 5.5" backspacing
Offline mjb765
« Reply #1034 on: August 15, 2016 - 09:17:33 PM »
Thanks
