Author Topic: E-Body Tire Combos  (Read 608181 times)
Offline 6PKRTSE
Re: E-Body Tire Combos
« Reply #1125 on: August 03, 2018 - 02:23:24 PM »
I can't remember without going thru all 75 pages of this post if I ever posted any or not of my Challenger? I have Weld Magnum 2.0's with 15X12's on the rear with M/T Drag Radials with a mini tub and rear springs relocated with Caltracs & split Mono-leafs.
1970 Charger R/T S.E. 440 Six Pack
1970 CHALLENGER R/T, 25.5 Cert, 528 Alum 16 plug HEMI twin turbo.
1970 Charger 500 S.E. 440 4 BBL.
1970 Road Runner 383 4 BBL
1996 2500 RAM 488 V-10 4X4
2012 Challenger R/T Classic
Offline darkside
« Reply #1126 on: August 12, 2018 - 05:39:30 PM »
So on a stock cuda e-body rear end and springs what the max backspacing that can be used without rubbing? 4.5?
Offline Aracer
« Reply #1127 on: October 11, 2018 - 04:43:07 PM »
On the rear, you can always add a 1/4"- 1/2" spacer to adjust the tire to spring to fender spacing. It depends on the tire side widths.
And math.
Offline ed-pv
« Reply #1128 on: December 11, 2018 - 07:42:46 PM »
Messing around in the shop, I was able to put 315's on the rear and 275's in the front of my challenger!  Looks great to me.  It does have a b-body Dana so there was about an inch more space on each side of the rear.  Fronts fit great.  Don't know the specs on the offset (just had them in my shop), but they are 17" wheels.
Offline 70chall440
« Reply #1129 on: December 11, 2018 - 07:58:39 PM »
Looks great, I have 315's on the rear of my Cuda but I have mini tubs.
Current Mopar
Past Mopars
Offline ed-pv
« Reply #1130 on: December 11, 2018 - 08:02:40 PM »
Looks awesome!  No tubs in mine...just had to trim the quarter lip.  LOVE 315's   I try to put them on all my muscle cars!!
Offline 70chall440
« Reply #1131 on: December 11, 2018 - 08:59:29 PM »
Thanks. I was shooting for 335's like on my Viper but couldn't get there  :bigsmile:
Current Mopar
Past Mopars
Offline droptail
  • KETCH JC
    • droptail
« Reply #1132 on: April 29, 2019 - 01:06:12 PM »
(Posted elsewhere)
After years of combo's, I finally came up with what I thought was the perfect set-up with BFG's on 15" rallye's.
Car is lowered all the way around with the biggest torsion bars MP had for circle track racing, and hemi leaf springs in the rear - KYB shocks.
Fronts fit fine, I had the rears made to get a 1/4" clearance from the leaf springs and just clearing the fenders after rolling them.
I would have to dig out my notes for specs - its been about 25 years.
Car handled well and looked perfect!
front: P275/50R15 (25.825" dia)
rear: P295/50R15 = (26.61" dia (24.9" OE) x 3.55 = 3.301 effective ratio)
Now I need new fronts & they are discontinued!
bought off the showroom floor: '70 Cuda convt - 383 bored/ported, Hemi cam, Rhodes, rollers, Mellings,  MSD, 780 Holley, LT dual 3", lowered, snubber, police chuck, discs, springs, sway bars, B&M, posi, shaker, split 15" rallyes w/295's, leather...
Offline djais1801
« Reply #1133 on: December 19, 2019 - 12:08:35 PM »
I've thought about doing that with my cop car rims as well as I have rallye caps laying around. You had to drill out the cop car rims to mount the centers correct?
negative...they bolted in.
Offline bc3j
E-Body Tire Combos
« Reply #1134 on: January 01, 2020 - 01:16:49 PM »
Mine bolted right in after some trimming of the mounting studs on the rallye centers. The police wheels had three predrilled holes in the hub. I used slightly shorter bolts to mount them. Pretty easy to do.
« Last Edit: January 01, 2020 - 01:21:30 PM by bc3j »
Offline rt green
  • third string oil changer
« Reply #1135 on: January 22, 2020 - 07:52:00 AM »
1970 barracuda. ordered the wrong rims for the rear. but will they fit the front? 15x8 4.5 backspace
Offline 70chall440
« Reply #1136 on: January 22, 2020 - 12:15:52 PM »
They might but a 4.5" back space might cause you some issues; mock them up and see.
Current Mopar
Past Mopars
Offline pinkmeepmeep
« Reply #1137 on: February 19, 2020 - 06:23:44 AM »
Here is a pic of my T/A challenger with 295 50 15's on 8" rallyes
« Reply #1138 on: February 19, 2020 - 06:25:10 AM »
Here is another
Offline darkside
« Reply #1139 on: April 10, 2021 - 05:01:20 PM »
Will this set up work with out rubbing  ? 15x10's rear with 5 back spacing   for front 15x8 with 4 1/4  backspacing ?
« Last Edit: April 11, 2021 - 01:25:31 PM by darkside »
