Author Topic: E-Body Tire Combos  (Read 608328 times)
Offline drewcrane
Re: E-Body Tire Combos
« Reply #165 on: February 21, 2008 - 07:38:25 AM »
i havent decided what will fit in the front,i might purchase a wheel measuring device so i can make it as tight as possible, stay tuned............. :cooldancing:
« Reply #166 on: February 21, 2008 - 09:25:41 AM »
No leaf springs.
No strut rods in the front suspension either.
They also use a rack and pinion steering set up, which I've heard has reduced wheel angle, so that helps reduce the prospect of scrubbing the wheel sidewalls inside the fenders.
« Last Edit: February 22, 2008 - 07:21:25 AM by HP2 »
Offline drewcrane
« Reply #167 on: February 22, 2008 - 02:21:28 PM »
humm now im thinking , does anyone have the rack & pinon set up? i wonder if they have a bump steer problem? that system would utilize a bigger tire in front :droolingbounce:
Offline drewcrane
« Reply #168 on: February 22, 2008 - 03:20:34 PM »
I just talked to scott at xv engineering , the biggest tire , and wheel combo they have put on a stock suspension., is 18x8 front wheel with a 245/49 /18., rear 18 x 9 265/40/18., cant put a 9 inch wheel in front there just isnt enough room! but this set up looks :money: good
« Last Edit: February 22, 2008 - 03:25:03 PM by drewcrane »
« Reply #169 on: February 22, 2008 - 03:44:32 PM »
That would make sense for a stock suspension, although that is a tad small for the rear. I personally think you can go woder than that, even with leafs int eh stock location, but wheel choice becomes critical.
They have put 275 front and 335 rear using the Level 2 system under a Challenger. Not sure of the wheel size they are using, but it is in here somewhere. You can search for it by looking for posts from dqhemi.
Bump steer on their rack system is minimal. Since it is a completely fabricated system with relocated pick up points, they wouldn't have the same interference issue as a rack retrofited to a stock suspension.
« Last Edit: February 22, 2008 - 03:51:03 PM by HP2 »
Offline drewcrane
« Reply #170 on: February 22, 2008 - 06:36:00 PM »
  how much clearence do you think is needed in relation to the inside of the wheel to the rear to the leaf spring?
Offline GoodysGotaCuda
« Reply #171 on: February 22, 2008 - 06:48:24 PM »
When i was sizing tires i believe the magic number was ~1/2" IF you are going with a thin sidewall tire. Going big tires on 15s and big tires on 18s is a different story on sidewall flex and clearances.
-Mike
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline drewcrane
« Reply #172 on: February 22, 2008 - 07:42:54 PM »
ah yes true 1/2 inch is goos i have that and then some and an inch or so on the out side so 9 inc wheel will fit,obviously you have it, so i will have to ponder it a little as to what i will do  :clueless:
« Reply #173 on: February 22, 2008 - 07:50:19 PM »
Come on over to florida and try a wheel on. lol
1976 Dodge Warlock
Offline drewcrane
« Reply #174 on: February 22, 2008 - 10:14:58 PM »
well now theres an idea! :bigsmile: :picture: :horse:i could
Offline autoxcuda
    • Spring Fling
« Reply #175 on: April 11, 2008 - 06:29:38 PM »
Are you set on 18" rims?
With stock suspension, if you run 17x9 with 5.5" backspacing rim in the front you can run a 275/40/17 tire up there. You need to have the flat type upper ball joints though.
See this site for 17" rim fitment: http://www.moparfins.com/CLAIRDAVIS/1969_front_end.htm
Here's a 68 Barracuda with 17x9 and 275/40/17 tires. If he can fit it on an A-body Barracuda, you can with your challenger. He had to cut/roll a ~3/4" by 3" triangle from the bottom front fender lip. www.conemangler.com
The 68 Valiant pictured here runs 17x9 and 275/40/17's also http://www.mrmopar.com/SpringFling2007/WillowSprings/
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
Offline S_Bruce
« Reply #176 on: April 16, 2008 - 09:26:22 PM »
I did a Stainless Steel Brake Co. conversion on my front drums, and since then my wheels have dragged on the calipers.  They were some 15x7 aluminum mags with approx 4" of BS.  I have a set of Magnum 500's that do not rub, but they are 14x7 and the rubber is shot.
What would cause the 15" rims to rub the calipers, when my other wheels do not?  They have approximately the same backspace...
What wheel combo's has snyone used with success out there after a conversion to disc brakes?  I'm ready to invest in a nice set of 16" or bigger rims, but do not want to shell out the money only to find that they will eventually wear holes in my brakes!!
1970 Challenger R/T (SE)
Offline easy610
  • Keeping Michigan zombie free one round at a time..
« Reply #177 on: May 29, 2008 - 01:22:09 PM »
15x7 4"BS - 245/60R/15
I went safe and conservative....
1972 'Cuda 340 4spd, Blk/Blk.
Sold November 2012.  Will be missed and fondly remembered...
Replaced by this..I know, I know it ain't no classic...but it doesn't rattle and is wicked fast even with AC on...
« Reply #178 on: May 29, 2008 - 10:20:09 PM »
Well, if they are an older set of mags,it is possible that they are drum brake wheels. Many moons ago before discs became standard on many cars, wheel manufacturers offered disc and drum wheels. It is possible to have identical back space, but a drum wheel will will have flatter spokes whereas a disc wheel will have some arch to it to avoid caliper interference.
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #179 on: June 06, 2008 - 02:22:34 AM »
Here's some pix of my Chally.  I'm in the process of changing some things, but nothing too drastic regarding the overall look.  However, I'm definitely changing the wheels and tires.  I'm thinking of going with with either 17" or 18" wheels.  Currently (from the previous owner) the wheels are 15" Weld Prostars (10" rear and 8" front).  Rear tires are BFG Drag Radials 315/60-15 (I think that's a 30" tall tire).  I'd like to go down in size by about 1 to 2 inches 'cause it's just too close to the wheel opening at the front side of the tire (about half an inch to an inch).  I can easily fit a 12" wide wheel (and tire set-up) in the back as the previous owner did a fantastic job of a 3" mini-tub with a leaf-spring relocation and going with an A-body 8.75 rear-end housing.  My problem has been finding a 17x12 or 18x12 that I like and a 28" or 29" tall radial tire that will fit the wheel width nicely without looking too much like rubber bands or balloons.  I'd certainly be open to the idea of staying with 15" diameter wheels as long as they're retro, muscle car looking and I can get them in 12" width, AND I can find a good looking tire.  I'd appreciate some help with wheel/tire options for my project too.  My preference in wheels is the Magnum 500s like those offered from Wheel Vintiques (billet and steel) and from American Racing.  Thanks
« Last Edit: June 06, 2008 - 02:25:53 AM by filmsurgeon »
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
