Author Topic: E-Body Tire Combos  (Read 608474 times)
Offline 72bluNblu
Re: E-Body Tire Combos
« Reply #240 on: June 30, 2009 - 02:46:47 AM »
275/40's will fit on an 8" rim, but according to most tires specs an 8" rim is too narrow for that tire. You'll need to run 5" backspace to make a 9" rim work, if not a little more. 5.5" is probably too much backspace though. It has worked for some and not for others (ah factory tolerances!). A 245/40/17 is going to be way short. If your car is too high with the new torsion bars you need to adjust your torsion bar adjusters, not buy shorter tires. 265/40/17's are not exactly a popular size, there are few choices but not a ton. And that's still only a 25.4" tall tire.
What size torsion bars are you running? If they're less than 1", you shouldn't have any problems lowering the nose of the car with the torsion bar adjustment. You'll need an alignment afterwards, but it won't hurt anything else.
On a set of 17x8's your best bet are probably 245/45/17's or 255/45/17's. A 245/45 is 25.7" tall (decent for the front), a 255/45 is 26" tall. Still fairly short for these cars in the rear, but 50 series are harder to find in that width. 275's will physically fit, and I know Mike Tyler is running them on 8" rims, but as I mentioned the manufacturer specs will ask for a 9" rim for that width, you can make your own call on that one.
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #241 on: June 30, 2009 - 07:49:58 AM »
Well said, I totally agree with that, 40s are too short a tire on 17' rims.  Can you get the same rim in 18" for the same price?  If you want to run 40s, I woundn't go smaller then that, and even thats short.
Your looking for something around 27" for the front, and 28" tall for the rear.   Stick with that and you'll be good.  Look at previous posts in this thread and you'll see a good link to a comparison website.   Plug in some known good sizes, and then it will tell you other sizes that will occupy the same space.
Good luck and please report back after your done.
Chris
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Offline Kevin71
« Reply #242 on: June 30, 2009 - 10:36:51 AM »
Thanks alot for the advice.  I have already read all 16 pages of the tire section.  This has been more work than I ever thought.  Of course back in the 70's you didn't have many choices.  It was much easier in the old days.  I remember having 14" rims and the muffler kept getting knocked off.  Of course when I was 18 a little extra noise wasn't much of a issue.  Would like to hear the music now.  When I get the tires and rims I'll post some pics.  Thanks.
Offline dandsgcuda
  • almost there
« Reply #243 on: June 30, 2009 - 07:10:44 PM »
 ;)my combo is 215 55 17 on a 17x7 and a 255 50 17 on 17x8 they are 26.4" tall in the front and 27" tall on the rear and they ride just fine. the tire brand is kuhmo ASX. the rears are almost 10.5" wide not much narrower than a 275
Offline Daves74chally
  • "Yea.... I need another new pair of tires"
« Reply #244 on: July 07, 2009 - 07:55:16 PM »
How do you guys with the 275 60 15 bfg, 15x8 with 4.5 back spacing in the rear manage to not rub. I have my new set on and i cant lower the rear too much or it will rub on the quarter.
1974 Dodge Challenger 414 stroker, 727 trans, 8 3/4 posi [OO/`````\OO]
Buffalo, NY
Offline Aracer
« Reply #245 on: July 11, 2009 - 05:51:07 PM »
Mine's a 74 barracuda, so that makes a difference, also I rolled the fender lip up.
Dr.Diff's 1" offset hangar set with a 68 Satellite housing will buy you more room, but they fit with out. Slicks are 12" section width instead of 11" for the 275x60-15" so I needed more room. Add leafs to yours for more height. :thinkerg:
Offline challngd73
« Reply #246 on: July 15, 2009 - 03:48:49 PM »
225-50-17's(17x7) in front, 255-45-18(18x8) rear.  Foose Legends
Offline 73Chally
« Reply #247 on: July 15, 2009 - 11:15:24 PM »
I had posted pics several months ago with my new 17" TTII's, but decided the tires (235-45/17 front, 255-45/17 rear) were too small for my taste, so I changed them out to 235-55/17 front and 255-60/17 rear.  Now the wheel wells are completely full.
« Reply #248 on: July 16, 2009 - 10:59:34 AM »
Those look great 73,  I didn't know you could get 60 series tires for 17" rims.
Cool.
PlumCrazyChris
Round Rock Tx
www.mopar.org
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
« Reply #249 on: July 16, 2009 - 11:16:17 AM »
Cool.
 :iagree: Could you post some more pictures of the fit of your tires.   :thumbsup:
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Offline 73Chally
« Reply #250 on: July 16, 2009 - 11:26:07 AM »
Cool.
Front and rear are Goodyear RS-A sport sedan/light truck tires.  The best part is I have 3.91 gears, and I run under 3000 RPM on the highway with a 4 speed.
Offline 73Chally
« Reply #251 on: July 16, 2009 - 11:26:55 AM »
I will try to get it out today for some more pics.  The 100+ heat here is a beating  :villagers: .
Offline jackie
« Reply #252 on: July 17, 2009 - 02:48:18 PM »
they are some nice cars on here, but i still like the old school look..15x3-1/2 front, 15x10 rear. but next time 15x12 rear..
1970 challenger r/t, prostreet 438 ci. 4 speed
Offline miketyler
    • www.miketyler.net
« Reply #253 on: July 17, 2009 - 06:34:28 PM »
You car has some clearance under it. I went the opposite way on mine when I put 17's on it
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline challngd73
« Reply #254 on: July 17, 2009 - 07:33:38 PM »
yeah, id like it to sit a little lower than it does.
