Author Topic: E-Body Tire Combos  (Read 607823 times)
Offline EVIL72
Re: E-Body Tire Combos
« Reply #30 on: May 20, 2006 - 09:44:12 AM »
 On the front of my Challenger I have 15x7's Centerlines with 3-5/16" bs on 225/60/15's that is the limit for this offset. My car is as low as I can put it without hitting the fender brace.
 I tried some 235/60/15's and they hit the low front fender when trying to turn.
 Why Centerline doesn't make some better offsets for mopars I don't know  :dunno:
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline 73Cuda73
« Reply #31 on: May 20, 2006 - 11:41:22 AM »
That's the information that I needed. Did any of you guys need to use any spacers with your Centerlines?
Thanks for the info.
ukneil
« Reply #32 on: May 21, 2006 - 10:07:31 AM »
have you looked at the Centerline AutoDragIII wheels? They have 15x8" with 4 1/2" backspace. I should be receiving mine next week after a long wait for a second delivery. The first lot got damaged in transit :swear: and they are made to order :pullinghair:
Anyway I took some photos before they were sent back to see what they would be like for spacing, 275/60/15 BFG waiting to go on :bigsmile:
Offline Prowler Orange Challenger
« Reply #33 on: May 21, 2006 - 12:12:50 PM »
Some pics of the new combo. 255/70/15 out back and 215/60/15 up front on 15x7 rims.
« Last Edit: June 17, 2006 - 09:44:45 PM by Rev-It-Up »
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
« Reply #34 on: May 21, 2006 - 01:02:59 PM »
Hey P.O.C. I like it.  That looks good. :cooldancing:  (BTW how do you get stuff done when you're always logged into this site? (LOL))
« Reply #35 on: May 21, 2006 - 01:25:19 PM »
Thanks ROMI. I just do it.
« Last Edit: May 21, 2006 - 02:52:48 PM by Prowler Orange Challenger »
« Reply #36 on: May 21, 2006 - 10:37:48 PM »
I keep them tight because I have the feel for it and as it looks bad Unfournately, I don't have any access to any air tools nearby and I don't make a ton of money at this point just yet. Call me a redneck mechanic but, sometimes you have to use what you have and I don't have a lot of the shops around here that I can trust to do the work being around a military base.
As for the front end I thought the same thing and that problem will be getting fixed. I bought the car like that. I'm young and I'm still learning on these cars.
Offline EVIL72
« Reply #37 on: May 22, 2006 - 12:19:50 AM »
Yea, but only for the back to get the 295/50/15's to fit,  all of my info is on page one of this post.
 Did these just come out?
 73Cuda73 go for these instead, much better backspace options!
Looks like I need to start saving  ;)
ROB
ukneil
« Reply #38 on: May 22, 2006 - 04:13:58 AM »
Offline 73Cuda73
« Reply #39 on: May 22, 2006 - 04:41:18 PM »
I was told that the AutoDragIII models were for RWD vehicles only. That is the perfect size with a perfect Back Space.
Offline 73Cuda73
« Reply #40 on: May 22, 2006 - 04:57:38 PM »
Would you recommned the 15x7 with the 4" backspacing for the fronts? I noticed the AutoDrag III have that setup with the 5 x 4 1/2 bolt pattern.
It looks like the AutoDrag III 15x8 with 4 1/2 back space would be perfect for the rear.
Offline 73Cuda73
« Reply #41 on: May 23, 2006 - 05:53:31 PM »
Thanks. I ordered the rims today and will get the tires when they arrive. I'll take some pics and post them. Thanks for all of the help.  :crazy:
Offline ntstlgl1970
  • T a c o c a t
« Reply #42 on: May 25, 2006 - 05:07:46 PM »
for 17's
I'm running weld EVO's 17x8 front and 17x9.5 rear on my car with 245/45R17's front and 305/45R17's rear. The front wheels are 5.7" backspace and  the rear is 5.9", Super Stock springs with 1" offset hangers, 3" (yikes!) lowering blocks, longer studs and 3/4" inch wheel spacers (rear only). The rear outer wheel well lips were cut (would be better to roll them). Would have liked to have a different offset, but choices were limited when I bought the wheels. I have a set of ET Streets for the track, 28x11.5 on 15x8 centerlines with 4.5" back spacing, no spacers. Last pic is a 275/40/17 on another 17x9 with 5.9" offset, I think it looks small but that is just me.
« Last Edit: March 28, 2010 - 08:51:17 PM by ntstlgl1970 »
Offline 70 rtse
« Reply #43 on: May 29, 2006 - 08:01:07 AM »
I am going to order 15*7 inch magnums for my 70 challenger what back spacing do i need or do i go for thr original 14 inch rims
Offline Carlwalski
« Reply #44 on: May 30, 2006 - 07:18:52 AM »
Try creating a new topic, you'll get a quicker response to your question and this thread is for combos, not questions.  :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
