I understand the offset and backspace are measured to the putside lip, where the wheel width is measured to the inside, so there is about 3/4" to 7/8" total difference with most wheels.
I measured the clearance from the mounting plane of my drum to the closest point of the leafspring and it came up 5-3/8". So about a 4.5" backspace ought to do it for me with a 275 tire. Problem is there is VERY limited selection for a 17" rim, unless you go to a 40 series, which I think is too low. I wanted a 50 series to give a slightly softer ride, and I think it will look better.
Any suggestions?
