E-Body Tire Combos
Author Topic: E-Body Tire Combos  (Read 608540 times)
Offline greenzeppelin
  • Thank you all for your help, its much appreciated!
Re: E-Body Tire Combos
« Reply #435 on: June 13, 2010 - 12:17:33 AM »
iits not letting upload any pictures....????
it says upload folder full please resize item or contact the admin.
So i resized it down to a 34.6 kb file..
Cody
1973 Dodge Challenger 340, 4spd, 18x8 & 18x9.5
1989 Plymouth Reliant (K-Car!!) 2.5L, auto SOLD!
« Reply #436 on: June 13, 2010 - 10:48:21 AM »
M/T S/R 26x10x15 front tires on 15x8 rims with 4.5" backspace. 26x12x15 rear tires on 15x10 rim with 5" back space. Rear springs moved in .75" with B body rear. 0 arch rear springs. Car has been lowered about 3" overall and I may go another couple inches if i can pull it off. I could go at least another inch wider in back, mabe even 2" if I rolled the fender lip. I could use another .25" of back space on the front and I could add another inch of tire up there, but hey, I got these wheels for $30 each, so I can't complain too much.
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #437 on: June 20, 2010 - 12:12:30 PM »
Rimes: front 18x8 rear 18x9.5
Tires: front 245/45-18 rear 275/40-18
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline TROUBLE987
« Reply #438 on: June 20, 2010 - 03:25:23 PM »
Is the rear stock?
Offline widing'cuda
« Reply #439 on: June 20, 2010 - 03:27:18 PM »
Is the rear stock?
As fare as I know. Yes
Offline TROUBLE987
« Reply #440 on: June 20, 2010 - 03:33:04 PM »
thats the same setup i want,but i got the b-body rear under mine and i dont think it will work with mine,so im looking for a stock e-body rear..i ordered a moser rear but i didnt like it at all...
Offline widing'cuda
« Reply #441 on: June 20, 2010 - 03:46:33 PM »
The e-body rear axel is winder then the b-body axel as fare as I know. So you should be able to fit wider tires with a b-body axel.
Offline kamstra
« Reply #442 on: June 20, 2010 - 04:18:29 PM »
The 67 Bbody is the rear I used.  This worked well with 9.5 rims.  You can fit the same size rims, regardless of the rearend B or E.  You just need to order the correct offset
1970 Barracuda Convertible
1968 Road Runner
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #443 on: June 20, 2010 - 04:45:36 PM »
You need to get the Dr Diff, 1.5" relocation spring hangers.  Its a cheap bolt on and give yous tons of room for wide tires.   Search for him in the threads for his contact info.
Chris
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
« Reply #444 on: June 20, 2010 - 10:39:02 PM »
The trick to using a B body rear is that you move the springs in, the B body rear sits right on top of them, and with no other mods, and you can put 13" wide tires under there. If anything other than this was done you the rear, then you have to figure out what rim back space and tire sizes will fit on a case by case basis. BTW, 65-67 B body rears will require less back space than similar 68-70 b body rears. All of this is explained through out the forum, and if your still confused, there is plenty of help here to sort it all out.
« Reply #445 on: June 21, 2010 - 02:13:44 AM »
those rims on the cuda look like Boss 338 rims..
the same ive got for my 73 challenger!!
the look real good on your ride!
***MODERATOR'S FIX THE UPLOAD ISSUE PLEASE
Cody
Offline widing'cuda
« Reply #446 on: June 21, 2010 - 05:22:40 PM »
Thanks! Yes there Boss 338 18x8 bs 4.5 and 18x9.5 bs 5.03 no mods doen to the rear at all. i chould have hade 295 tires without any problems. But i wanted the same diameter on the front and rear tires and i got this with 245/45/18 and 275/10-18.
Offline 440mike
« Reply #447 on: July 13, 2010 - 11:02:01 AM »
i was thinking about new wheels for my challenger
but,
i went for a ride in a friends road runner with 18 wheels, and i was very surprised how rough riding it is ?
it seems to handle very well, but man, is it ever bumpy and choppy?
is this normal with the big wheels or is something wrong with his car ?
btw,
buddys road runner looks really stupid with the 18 wheels and low profile tires, i think the car may be to big?
Offline tommyg29
« Reply #448 on: July 13, 2010 - 01:58:10 PM »
I have 17s with lower profile tires (245/45 up front) and the lower profiles definitely give a sharper ride than the oem tires!
I also have big torsion bars and hemi springs, so every pothole or bump jars my bones and makes me cringe.
Offline cudazappa
« Reply #449 on: July 14, 2010 - 03:38:17 PM »
i have 245/45 17s as well, and I really need to up the $$$ to bilstein, koni, or QA1 shocks.  Problem with the shocks spec'd out for the e'body, they aren't designed with the wheel rates that we install into our cars.  1"+ t-bars and bigger sway bars need better shocks.  1" is just passable right now in my car... and I want to go HIGHER on my wheel rates.
2015 Dart GT - Daily Driver
