Author Topic: E-Body Tire Combos  (Read 608502 times)
Offline Kevin71
Re: E-Body Tire Combos
« Reply #465 on: October 28, 2010 - 11:32:26 AM »
Whats the most backspace you can put on the front wheels.  I can't seem to get a 17x8 rim much inside the fender well.
« Reply #466 on: October 28, 2010 - 02:42:23 PM »
I've had 4.75 backspace on a 15" rim, and that is as close as I could go to the upper ball joint. In a 17", you may be able to get away with 5", bu tI'm not sure.
See what Mike used; http://www.cuda-challenger.com/cc/index.php?topic=42140.0
Offline cudazappa
« Reply #467 on: October 28, 2010 - 02:53:58 PM »
I am running a little over 5" backspace right now on 17x9 rims on the front.  On 17x8s 4.5" worked fine, except on hard turns at full lock and suspension movement (rubbed at the very top).  So both combos rarely rubbed.  I'm going to increase the backspace in the front when I go to 13.1" rotors in the front.
2015 Dart GT - Daily Driver
Offline Kevin71
« Reply #468 on: October 29, 2010 - 12:36:38 PM »
I have SSBC disc on the front and was told by Coy wheels that the add about a inch over the drums.  I have 17x8 4.5 back space.  Have about 1/2 inch before it hits the upper A arm.  The car has to be raised a least a inch above the wheel to prevent it from rubbing when you turn the wheel.  I tried a torq thrust m with 5.62 inch of back space it hits the upper A arm.  Added 1/2 spacer and still hits the A arm.  So I am going to try a 17x7 with 4.5 inch of back space and see if I can get the front down a little.  I am running 17/45/235s on the front.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #469 on: November 06, 2010 - 06:54:51 PM »
I go 17 - 7 in front, 4,5" BS - and rub fenders..??
Offline Kevin71
« Reply #470 on: November 10, 2010 - 08:44:50 AM »
I have just got a set of Coy's 18/9.5 for the rear with 5.5" of back space.  I was thinking of putting a 275/55/18 on them which would be right at 31" tall.  Would these be to tall.  I wanted to get the rear end to sit a little higher.  I hope to get all of this put together within the next week and get some pics posted.  I think the taller tires would fill the fender wells good.
Offline inviolet
« Reply #471 on: November 10, 2010 - 09:41:04 AM »
You might want to run a 31' Tall tire through this calculator with your trany/rear and see how it effects performance before you buy anything.
http://www.americantorque.com/graph-rpm-vs-speed/
« Last Edit: November 10, 2010 - 01:57:11 PM by inviolet »
Offline Kevin71
« Reply #472 on: November 10, 2010 - 10:10:31 AM »
I've got 391 gears in the rear end
Offline inviolet
« Reply #473 on: November 10, 2010 - 10:40:40 AM »
That will roughly give you 3,000 rpm at 70 mph with a 31' Tall tire and a 3 speed Trany.
« Last Edit: November 10, 2010 - 10:50:11 AM by inviolet »
Offline Kevin71
« Reply #474 on: November 10, 2010 - 01:29:26 PM »
I have a 5 speed tremec.  I think I better go with a shorter tire.  Just make life a little simpler.
Offline inviolet
« Reply #475 on: November 10, 2010 - 01:50:43 PM »
Yes defiantly. I have a TKO 500 with 3.55's and 26' tall tire. About 2200 rpm at 70 mph. It's hard to find a happy medium.
Offline solarguy
« Reply #476 on: November 10, 2010 - 02:52:29 PM »
a taller tire will give you LOWER RPM's at the same MPH
Offline Kevin71
« Reply #477 on: November 10, 2010 - 07:41:27 PM »
It's hard to find a tire that fits a 18 inch rim that is say 28-29 inch tall that's not a SUV tire.  I want to stay with about 9.5-11 inches wide in tread.  Also don't want to spend $400. for a tire.  I am sure you can understand.
Offline GoodysGotaCuda
« Reply #478 on: November 10, 2010 - 08:08:07 PM »
my 295/45/18 nittos are 28.5" tall, 11.6" wide and $200 a tire..
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« Reply #479 on: December 12, 2010 - 03:13:25 PM »
I want to run the AVON CR6zz tires 245/60/15 and 275/55/15 on my superlites or minilites.
Jackson from Toronto.
