Author Topic: E-Body Tire Combos  (Read 608131 times)
Offline GranCuda1970
Re: E-Body Tire Combos
« Reply #570 on: May 16, 2012 - 11:37:50 PM »
1970 barracuda Gran Coupe
P195 60 r15 97s fronts
p245 60r15 100s rears
Looks like I gots room for bigger!
« Last Edit: May 16, 2012 - 11:45:27 PM by GranCuda1970 »
Offline Jamie
« Reply #571 on: June 10, 2012 - 10:56:43 PM »
 I may have gone cross-eyed now! I have red this thread 6 times! My question is that after spotting a deal on some goose wheels i hope the offsets work. My 70 cud a has a pretty stiff suspension and has relocation kit 3/4" . FRONT HOTCHKIS UPPER ARMS ALSO. wheels i found are 18 x 10 with 6.25 backspace, 18 x 8.5 with 5.25 backspace. After reading this thread, I feel a 1/2" spacer may make these perfect for me. tires are 275/40 & 245/40. any ideas?
I will finish a project.I will finish a project. I will finish a project.
70 barracuda plum crazy
( current goal is to keep just one car) AND FINISH IT!
08 charger r/t  w/road & track package
2011 silverado
Offline 72bluNblu
« Reply #572 on: June 13, 2012 - 05:54:32 PM »
Fronts should work as is, and you could run a wider tire than that too.
Rears might actually fit too if you have an E-body rear end. I have a B body rear end in mine with a 1" relocation kit, and I don't have the 1.5" of extra clearance I'd need to run 18x10's with a 6.25 backspace vs my current 17x9's with a 5 backspace and 275/40's. But an E-body rear would make up most of that space, so they actually might fit. If you have a B rear though I think you'd probably need that 1/2" spacer, maybe even 3/4".
Offline Jamie
« Reply #573 on: June 13, 2012 - 09:37:47 PM »
I ment "foose" wheels! polished nitrous 2`s . Thank you for the reply. i have a stock e-body rear. also disc brakes in rear which i think bumps the wheels out an extra hair.
2011 silverado
Offline 72bluNblu
« Reply #574 on: June 13, 2012 - 11:00:25 PM »
With a stock E-body rear, offset kit and the disk kit in the back you might not even need any spacers. If you did I would think they'd be less than 1/2" for sure.
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« Reply #575 on: June 26, 2012 - 12:03:14 AM »
Hey all, I've looked through this thread and there are a bunch of posts that don't have images anymore. I'm probably going to go with 17x8 with 4.5" BS all the way around. What I'd like to see is some images of what those look like before I make my final decision. I'd like to have the rims fill out to the fender as reasonably close as possible. It's an awful lot of $$ to make a wrong decision and be unhappy with them.
Anyone?
Offline tommyg29
« Reply #576 on: June 26, 2012 - 07:48:45 AM »
back around post #330 I have pictures of what a 17x8 with a 4" backspace looks like up front
Offline peterro
    • The Pistonhead
« Reply #577 on: June 26, 2012 - 11:31:32 AM »
Looks like 4" is a better fit. Is/was the difference on the rear about the same? I'm not looking to get super close to the fender and risk rubbing, just trying to fill them out.
Thanks.
Offline ragtopdodge
« Reply #578 on: June 26, 2012 - 12:58:36 PM »
Anyone?
Why not do a staggered setup?  Looks better IMHO.
17x8F, 17x10R.  Just get a Dr. Diff re-location setup.  4.5" BS F, 6" BS R.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline peterro
    • The Pistonhead
« Reply #579 on: June 28, 2012 - 01:52:39 AM »
I just did some eyeballing of a Foose wheel that my father-in-law loaned me from his Roadrunner. It's a 17x9 but I'm not sure of the backspacing. I put it on the front and it clearly needs to come out more. I like the way the 17x8 4"BS that tommyg29 posted.
I then moved it to the back and it could have moved out a little but not much. Now I'm wondering if the 17x8 with 4"BS will work all the way around. He had a Goodyear 235 50 17 on the rim and the tire sticks out from the rim a good 3/8"
Is there typically more room in the front fender than the rear?
Offline tommyg29
« Reply #580 on: June 28, 2012 - 09:14:38 PM »
from what I remember, there is a lot more room to play with in back. If your car is stock or close to it, 17x8 will fit all around, but if you dont have the exact proper backspace up front, you may have to trim the front corner of the fender a tiny bit.
If you dont mind possibly having to trim a little up front, you can probably fit up to 17x9 up front, but out back I have seen up to 17x10 without modification.
But....keep in mind what works on one car may not work on another when you are cutting it close. Our cars are now 40 years old, and unless youve owned it the whole time, who knows what prior owners may have done to throw you off.
Im a building contractor, and my first rule is always...measure twice, cut once. Same applies to buying new wheels!
Offline 72bluNblu
« Reply #581 on: July 01, 2012 - 03:06:54 PM »
I run 17x9s with 5" backspace and  275/4017's up front on my Challenger. Even sitting as low as it does it clears the drivers side just fine, but has a slight rub on the passenger fender lip. So, fitting is definitely an issue, don't assume what will fit my car will fit yours, as what fits the left side of my car doesn't exactly fit the right side.
I think with 4" of backspace and 17x8's you're right at the edge of fenders, and you may or may not end up hitting the fender there. Those specs will put the outside face or your rims in the same exact place as mine, and I have  a minor rub on the fender. But still plenty of room to the inside, I'd be inclined to run 17x8's with a 4.5" backspace (more common too!), or even a 4.25" backspace if you can find it or have it made. With the 17x9's on my car, I think 5.25" of backspace would be about perfect (with stock spindles to clear the tie rods, drop spindles won't clear 17x9's with a 5.25" backspace).
Offline EDGECRUSHER
« Reply #582 on: July 05, 2012 - 12:14:35 PM »
OK, lets get a tire/tyre size combos thread started. Too many wasted threads about one topic.
Chryco if you or Ross or someone could sticky this topic that would be good.
Post what rear end you have, tire size, wheel size + back spacing etc
Also any mods or relocation kits that were needed to fit your wheel combo along with photos, definitely PHOTOS.
I'll go first:
1970 Dodge Challenger R/T
8-3/4 SureGrip
15x8" Rallyes Rear with 275/60 BFGoodrich Radial T/As
15x7" Rallyes Front with 245/60 BFGoodrich Radial T/As
Chrysler Rallye wheels: 56 Series purchased from www.jegs.com All wheels have a 4-1/2" (4.5) Back Spacing.
Rear trim rings leave a 1" gap due to the wheel being 8" and repro/OEM rings only available in 7" sizing.
No rubbing, no relocation kits, no worries.  :thumbsup:
Cheers,
NZ440R/T
I'm about to buy the Firestone Indy 500's with rallywheels
but i was thinking going 235/60 for the front.. you don't have problems turning with 245's on the front?
Offline EDGECRUSHER
« Reply #583 on: July 05, 2012 - 12:15:55 PM »
Panther Pinks Combo:
295/50 R -15 with little clearance to the leaf spring.  Fits inside the wheel wells though.
the pics with the 295 wheels wont show up?
Offline Jamie
« Reply #584 on: July 05, 2012 - 07:57:11 PM »
stock rear axle, dr diff relocation kit, disc rear, 18x10 w/275/40/18  6.25 backspace. front are 18x8.5 w/ 5.25 backspace( needs 1" spacer to look right though) 255/40/18 bf goodrich .mopar springs in rear, 1.06 torsion up front with adjusters cranked out.
2011 silverado
