News:
The tires are Goodyear Eagle GTII fronts are 235/60-15 and rears are 275/60-15. In looking at the web site it appears the offset is -24 with a 3 3/4 BS.
Here's another with 17" Coddington Smoothie II'sFront: 17x8 w/4.25 BS and 245/45-17 rubberRear: 17x10 w/6.0 BS and 275/40-17 rubber...lots of room to spare-1/4" on inside, over 1/2" clearance on the outside. The shorter tire would also allow for a lower drop as there is more distance from the wheel to fender well.
I've been reading the posts and couldn't help but ask a question. My car is a 1970 and the driver side rear tire is a bear to fit wider tires in. I think I'm running a 245 size tire in the rear and can't imagine running anything bigger without doing some suspension adjustments. I'm using rallye 15X8 rims so that isn't my problem. I've had the rear quarter panel replaced and could that be my problem? I'd like to have some wider tires in the rear but on my car it doesn't seem realistic. Can someone give me the scoop on why the tire and rim limitations are so much lower on my car?
