Have you looked at what 15" sizes are readily available in your desired sizes first? If you have some boutique size that is a low demand odd ball, chances of it being discontinued sometime in the near future are very good. You'll want to stick with sizes that have a good chance of continuing in production for some time. This means 235/60, 255/60, 275/60 and 295/50 are your best candidates.
I run something close to a 255/50-15 on the front of mine (its actually a 26x10). I've done it with a 4.75 backspace rim and it was close enough to the fender lip to motivate me to roll the edges in a couple of places. With a 4.5"ish" backspace and a 60 series tire, you are putting yourself in position for some conflict. It isn't impossible, but it may require either a narrower rim, like Carlwalski has shown above, a narrower tire, a shorter tire, or some fender mods.
If you start running short wide or tall narrow tires, you end up with unusual combo in the rear that may look out of place.
