Author Topic: E-Body Tire Combos  (Read 608028 times)
Offline HP_Cuda
  • Mopar or No Car!
Re: E-Body Tire Combos
« Reply #645 on: June 12, 2013 - 06:14:00 PM »
What tire size?
Ideally you want 4.5" backspacing.
Will 4" backspace work ok on a 71 Cuda on 15x8 wheels? I am about to place an order ASAP. Appreciate all feedback!
Offline 55gasser
  • V-code
« Reply #646 on: June 13, 2013 - 01:49:08 AM »
What tire size?
255/60
I see both Summit and Jegs are out of stock of 4,5 backspace. Anyone know who carries them in stock for urgent shipping?
Norway
BS23V1*****
Offline 1970 440 RT's
  • 1970 RT
« Reply #647 on: June 15, 2013 - 03:17:24 PM »
Anyone have pictures of the new 17" Rallye wheels from YearOne on a challenger?
..the only pic's I have seen, the 17s look too big on the front.  Maybe they should make a 16?
..But I would like to see more before I pass judgement...
or if they give me a smokin' deal on a set, I will put them on my car and display pics  :bigsmile:
« Last Edit: June 15, 2013 - 03:19:18 PM by 1970 440 RT's »
Offline 72bluNblu
« Reply #648 on: June 15, 2013 - 05:59:02 PM »
Think these were posted on here somewhere. 17's are great, just requires the right stance. I would say on this car it needs to be about a 1/2" lower in the front. I run 17's all the way around on my Challenger, think they look great! :2thumbs:
Offline ToxicWolf
« Reply #649 on: June 15, 2013 - 07:21:51 PM »
72bluNblu, do you know the wheel and tire sizes on that one?
« Last Edit: June 15, 2013 - 07:24:17 PM by ToxicWolf »
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
E-Body Tire Combos
« Reply #650 on: June 15, 2013 - 08:01:49 PM »
I test fit my 18's this weekend. I need a little more tire, but other than that, I love em!
Now time for body work and paint!
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline 72bluNblu
« Reply #651 on: June 15, 2013 - 08:36:41 PM »
Not beyond knowing that they're the Year One Rallye's, so that makes the rims either 17x8 or 17x9.
I think I downloaded the pictures from a thread on here somewhere, it may have more info.
Offline ToxicWolf
« Reply #652 on: June 15, 2013 - 08:40:17 PM »
Does anyone has shots of the Year One magnums in 17 inch. I'd love to see those too.
Offline 72bluNblu
« Reply #653 on: June 15, 2013 - 08:42:47 PM »
Here you go, rest of the info is here http://www.cuda-challenger.com/cc/index.php?topic=88098.msg892521#msg892521
Car and photo's belong to MetalMilitiaSRT.  :2thumbs:
They're 17x8's with 245/45/17's in the front and 17x9's with 275/40/17's out back...
Offline ToxicWolf
« Reply #654 on: June 15, 2013 - 08:52:52 PM »
Thanks 72bluNblu!
Offline 72bluNblu
« Reply #655 on: June 15, 2013 - 08:53:05 PM »
See this thread here http://www.cuda-challenger.com/cc/index.php?topic=90154.0;topicseen
Offline diyhemi.com
    • DIYHEMI.COM
E-Body Tire Combos
« Reply #656 on: June 15, 2013 - 09:06:37 PM »
Fronts are 18x8 225/40 nitto
Rears are 18x9.5 245/40 nitto.
I'm moving the 245's to the front and getting 285's for the rears
« Last Edit: June 15, 2013 - 09:08:50 PM by YellowFin »
  • 1970 RT
« Reply #657 on: June 16, 2013 - 02:50:25 PM »
I have seen that gray one 72-74 challenger with the 72-74 center caps.
Any other pictures anyone has of the 17" Rallyes from YearOne on a 70-71 with the 70 or 71 center caps?
Please post tire sizes too!
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« Reply #658 on: June 16, 2013 - 03:38:34 PM »
Did a wheel fitment test last weekend. These are Foose wheels from my father-in-law's Roadrunner. These aren't the wheels I want, but they sure do dress up the car and get me excited about the wheels I do want. They are 17x9 with 235 40 17 Goodyear. I'm not sure what the backspacing is. The point of the exercise was to see what would fit and what offset I wanted.
The fronts fit great and filled the fenders well but the rear need to come out about an inch. I've decided that I'm going to go with a 17x9 front and an 18x9.5 rear. Still need to work out what the offset will be when I have the $$ to purchase.
Offline 72bluNblu
« Reply #659 on: June 16, 2013 - 11:16:22 PM »
235 is awfully narrow for a 9" wide rim. I run 275/40/17's on my 17x9's (front and back). And short, a 235/40/17 is only 24.5" tall.
As far as offset, you'll want pretty close to 0 offset with a 17x9". That's what I have on mine, 0 offset, or 5" backspace. A little more would be good, I think 5.125" backspace is absolutely ideal. At most 5.25" backspace, which is a 5mm offset. But any more than that and you'll hit the tie rod ends with a 17" rim.
In the back, you'll probably still want about 0 offset on an 18x9.5, which is 5.3" backspace. That will put you right up on the stock springs, you might need to run a small spacer. But much less than that and you'll be into the quarter with the tire. A 275/40/18 (or 17) is about as big as you'll be able to go without at least offset hangers, like Dr. Diff's 1" offset kit.
