Author Topic: E-Body Tire Combos  (Read 608102 times)
Offline AU6pack
Re: E-Body Tire Combos
« Reply #735 on: April 10, 2014 - 11:46:01 AM »
Still raining here in the Pacific Northwet...
Still???
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #736 on: April 10, 2014 - 04:39:58 PM »
Still???
OK, Always...
May get a break this weekend.  :bigshades:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline Cudaragtop
« Reply #737 on: April 12, 2014 - 10:20:39 PM »
Still???
A nice day to get the Cuda out finally.
Firestone Wide Oval Indy 500 on Year One Rallye Wheels Front 245/45R17 17"x8" 4.5" BS, Rear 275/40R17 17"x9" 4.5" BS
Both front and rear tires are 25.7" tall. Still sitting on old suspension. Every corner is a different height right now... :screwy:
That should change when I get all the new suspension on. Torsion Bars, ESPO Leafs... :working:
« Last Edit: January 08, 2015 - 09:24:59 PM by Cudaragtop »
- Randy D.
Offline hemiken
« Reply #738 on: April 13, 2014 - 02:58:01 AM »
That really is a nice wheel package on your car, i will be buying a set of them for my convertible for sure :clapping:
« Reply #739 on: April 13, 2014 - 08:07:51 AM »
 :iagree: looks great!  :clapping: :2thumbs:
Offline AU6pack
« Reply #740 on: April 13, 2014 - 06:11:25 PM »
They do look awesome  :droolingbounce:
Craig
Offline dvldwg89
  • Semper Fi
« Reply #741 on: April 22, 2014 - 07:44:41 PM »
So I'm looking at new rims now. I'm going 15 inch. Problem is the rims I want  don't come in the right backspacing. 15 x 8 in the rears calls for 4 1/2 inch backspace. The vision rims I'm looking at are 4.44 inch backspace. Fronts are 15 x 7 4 1/4  inch backspace. The visions are 4.17 inch backspace. With a 275/60 15 tire in the rear I'm worried that it won't fit properly. Any ideas?
« Last Edit: April 23, 2014 - 04:42:00 PM by dvldwg89 »
Offline SBDave
« Reply #742 on: April 23, 2014 - 01:38:47 PM »
Those aren't off by that much, I'm willing to bet they'll work.  I assume you meant 275/60R15's.  I would still take careful measurements as every car is different.
Offline dvldwg89
  • Semper Fi
« Reply #743 on: April 23, 2014 - 04:43:06 PM »
Ok. What is the best way to measure?
Offline austinbbmopar
« Reply #744 on: May 13, 2014 - 10:21:52 AM »
Looks great! Would you happen to have a picture from the rear showing the width of the tires? :picture:
How much clearance on the rear tire? Did you roll the fender?
sorry i took so long to respond.... this is the best i have at the moment
Offline ragtopdodge
« Reply #745 on: May 16, 2014 - 06:58:24 PM »
Adjust those torsion bars.  They make a big difference of height on all four corners; not just the front.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #746 on: May 17, 2014 - 10:29:52 AM »
I ran a 15x8 with 4.75 back space and a 295 tire. It was about .5" to the front segment of the leaf spring and 1.25" to the opening lip, but they fit. I would think a 4.44 back space with a 275 would fit fine.
Compare it against what you have now. What is your current rim spacing and tire size? How much bigger is 275 and what is the change in spacing? That should give you a visual of the change After all, we are only talking about a 1/16 of an inch difference from the ideal 4.5 spacing.
Offline Cudaragtop
« Reply #747 on: May 17, 2014 - 10:45:24 AM »
Yup, on my to do list. :2thumbs:
- Randy D.
Offline dvldwg89
  • Semper Fi
« Reply #748 on: May 21, 2014 - 07:30:11 PM »
My rims  are 14 x7  3.5 backspace. 215 70r 14. Big difference from a 275 14
« Reply #749 on: May 22, 2014 - 12:37:22 AM »
215/70r14 is 26.9" tall and 8.7" wide. 275/60r15 is 28" tall and 11" wide . So your 1/2" taller from center. No big deal. You are also 1.15" wider per side, but call it 1 1/8" for simple measurements and fudge factor. Probably no big deal here either, but lets check.
With a 4" backspace rim you would have the same zero offset on a 15x8 as your 14x7 with 3.5" backspace and relating the above measurements would be simple tape exercise of adding in the extra dimensions against your current combo.
However, your chosen rim has 4.44" backspace which means it is .44 offset from zero. So you have to add .44 to the 1.15 for 1.59" That means you new combo will put the tire sidewall 1 1/2" closer to the leaf spring than your current combo. On the outside, we take out 1.15 wider tire and subtract .44 and get .71. That means your new combo will be just shy of 3/4" wider towards the wheel opening side than your current combo. So you can check: if you currently have more than 1.5" from the sidewall to the rear segment of the spring pack, (don't forget E body springs are splayed wider in back),  then your new combo will fit. Some on the outside, if you have more than 3/4" to the fender lip, it fits.
Now that you know how these dimensions compare, the change to a 4.5" backspace rim would add an extra .06 or 1/16" measurement to the spring side and subtract the same 1/16" from the fender side and you can see the difference between the 4.5 rim and the 4.44 rim.
Or you find a friend with the same combo, borrow his rim, and test fit it, have a beer, shoot the breeze.
