Author Topic: E-Body Tire Combos  (Read 608218 times)
Offline erat340
Re: E-Body Tire Combos
« Reply #990 on: January 28, 2016 - 09:30:15 PM »
Thanks MM!! Backing up, in a tight turn, does your tread scrape the front lower edge of the fender/ trim? Mine did, long ago, old tires, dont remember the size.....lol
« Last Edit: January 28, 2016 - 09:39:54 PM by erat340 »
Offline Mopar Mitch
« Reply #991 on: January 29, 2016 - 12:33:25 PM »
ERAT340 -- no rubbing on the front edges of the fenders, nor upper lips (rolled lips and slightly pulled... but again, I've got a stiff suspension, so, hardly any dipping at all.... even considering that my car is lowered f/r.
My fenders are slightly modified to accommodate 16x10 rims (5" back spacing... pushing the tires out towards the fenders ~1/2" from a stock dimension setup) with 275-45-16 DOT Hoosiers A6 race autocross tires.... no rubbing and just enough clearance.
If you'd use correct offset/backspacing, then the 255-60-15 will work without any problems, nor any need to modify the fender (again, tucking the lips for additional insurance would be the most needed to do).
One thing, perhaps with most wider tires, or taller tires, too, is the front rear inside will rub slightly against the frame rail when turned to a lock... no big deal.. just a bit of rub.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #992 on: February 19, 2016 - 09:11:16 PM »
My '70 Cuda finally got her new set of shoes.  Hankook Ventus V12 245/45/18 and 275/40/18 with US Mag U111 Rambler textured gunmetal grey 18x8 and 18x9.5.  Stock spring location gives abut 3/4" room, fits inside the rear quarters with no rolled lips.  Fronts also fit perfect, no rolled lips, not rubbing on frame.  I will say if you have soft shocks you may hit your fender on a hard bump or pothole while on a hard turn.  I have Hotchkis Fox adjustable shocks and do not hit at all.
Offline shawge
  • Zoiks!!
« Reply #993 on: February 19, 2016 - 10:00:22 PM »
Looks great  :2thumbs:  Hotchkiss torsion bars, too?
Edit: Oh yeah, what BS are you running?
« Last Edit: February 19, 2016 - 10:14:16 PM by shawge »
- Jerry
Offline ed-pv
« Reply #994 on: February 19, 2016 - 10:11:25 PM »
So SWEET!!
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #995 on: February 19, 2016 - 10:16:25 PM »
Looks Great!  :2thumbs:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
« Reply #996 on: February 19, 2016 - 10:43:36 PM »
 :iagree:  Looks really good!  :2thumbs:
Offline Archialfa
« Reply #997 on: February 20, 2016 - 03:04:57 AM »
Great looking! The same tyre setup I'm planning to do...
1970 Challenger 440 Magnum
Build thread: http://www.cuda-challenger.com/cc/index.php?topic=113902
Offline dfrazz
« Reply #998 on: February 20, 2016 - 08:49:22 AM »
Thanks guys.  BS on 18x8 is 4.5" and 18x9.5 are 5.25".  http://us-mags.com/rambler-u111-w-6133.htm
I did install Hotchkis 1.10" t-bars, front and rear sway bars, the fox shocks and Moog offset bushings.  It handles SO much better now.
Offline Cuda_451
« Reply #999 on: March 13, 2016 - 11:39:55 PM »
What tire combo would I need for 15x10 rear and 14x7 front wheels. I have a Narrowed rear end and air shocks. Just need to know what would look good. Thanks!
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Offline Cuda_451
« Reply #1000 on: March 14, 2016 - 11:18:43 PM »
Offline 72bluNblu
« Reply #1001 on: March 18, 2016 - 12:32:21 PM »
We really need more information about your car and wheels. What are the dimensions of the rear end (how much was it narrowed)? Are the springs relocated to the frame rails? Has the car been mini-tubbed? What is the backspacing measurement on the wheels?
Without that info there's really no way to figure out what will actually fit on your car.
Offline 734406pk
  • Andy
« Reply #1002 on: March 18, 2016 - 09:11:55 PM »
Looks great!!
Offline AARuFAST
  • AARuFAST
« Reply #1003 on: March 18, 2016 - 10:41:22 PM »
Nice Choice.  L@@K'in Good.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline RUENS 440 CUDA
  • SCATCUDA
  • MOPAR OR NOCAR
« Reply #1004 on: April 30, 2016 - 10:16:52 PM »
15X5 front RACESTAR INDUSTRIES with 205/65/15 and rear are 15X8 with 4.5 backspace 275/60/15.....Tons of clearance inside and about 2 fingers to outer lip
