Author Topic: E-Body Tire Combos  (Read 608422 times)
Offline ShelbyDogg
Re: E-Body Tire Combos
« Reply #180 on: June 06, 2008 - 07:50:48 AM »
I have a friend that just had a set of 15x12 magnum 500s made up for his Roadrunner. One of the popular wheel companies did it an had to weld up a 12" width wheel, because nobody made one in steel. It cost him a total of $1200 for 2 wheels! He also had some problems with their workmanship.
Good Luck!
Rob
Offline scottylack
« Reply #181 on: June 08, 2008 - 11:55:44 AM »
Can I get a 245/60/15 on a 70's rally wheel  ...I think its  a 15/6.5  ....  let me know  what you think...
Offline wiging19
« Reply #182 on: June 08, 2008 - 07:51:03 PM »
Shouldn't be a problem.  If you have a 70 ebody it might be tight on the drivers side if you've had work on the rear quarter panel.  Sometimes they don't repair the quarter quite right.  That happened with my car.  Most people put a 225 on front and up to 275 on the rear.  Some people have that size all the way around.  Its your call.
Offline Daves74chally
  • "Yea.... I need another new pair of tires"
« Reply #183 on: July 05, 2008 - 01:46:39 AM »
Hey guys it seems like this would be the place to ask this question.  Because of some very bad balljoints my camber got set way off on both sides and ate away at my tires. since im young, pay for the gas, and go to college i didnt fix it right away and just rotated my tires, did burnouts, and drive on them every day :burnout:. Now im looking for new rims and tires  I dont want to use my AMC rally  rims cuz they will do nothing for me since they are 14x6.  Just looking to get alot more rubber on the rear.  I was looking into some cragar ss wheels thinking 15x7 and 16x8. I was just wondering what you guys think the backspaceing should be. I would like not to have to do any modifications if i dont have to.
« Last Edit: July 05, 2008 - 02:03:12 AM by Daves74chally »
1974 Dodge Challenger 414 stroker, 727 trans, 8 3/4 posi [OO/`````\OO]
Buffalo, NY
Offline GoodysGotaCuda
« Reply #184 on: July 05, 2008 - 10:13:13 AM »
You did change your ball joints right, if not, you do realize what can happen? Ball joints causing bad camber wear is a REALLY bad ball joint.. As far as 16", make sure you shop tire sizes before you buy any 16" wheels. I think you will find more wide/tall 15 and 17 inch wheels than you will 16...just keep your options open.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #185 on: July 05, 2008 - 05:29:44 PM »
Yea i duno why i said that. I mean 15x7 15x8. Dont worry I replaced all the ball joints, bushings, and tie rods.  They were some really bad ball joints. I also had one bent lower control arm. But all that is fixed now and im onto the next step. Tires!
Buffalo, NY
Offline dwbiggs
« Reply #186 on: July 17, 2008 - 02:58:36 PM »
AR TTO's, 17x8 4" BS, Kumho ASX 235/50-17 front, 255/50-17 rear.
1974 Challenger Rallye - 440+.040, 0 decked, 10.5:1, Ross Pistons, Hughes 3844 cam (238/244, .536/.540), Eddy RPM manifold, Eddy aluminum heads, Holley 750, TTI headers, .96" T-bars, IAS shocks, 1 1/8" front sway bar, 3/4" rear sway bar, XHD 6 leaf springs, Firm Feel stage 2 steering box.
Offline nqkjw
« Reply #187 on: July 28, 2008 - 08:03:29 AM »
Centerline Autodrags Rear 15x8.5 with 4.75 backspace and 275/60/15
Front 15x5 with 165/85/15
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #188 on: August 01, 2008 - 11:59:42 AM »
Stock BS is 4.5" front and rear.  You can go as far as 5.5 on the rear with 255/60/15, but stay with stock on the front.
A really great look, is the magnum 500s with BFG TAs.  I had them on my convertible and put them on my coupe for a while.  15x8s  with 255/60/15 on the back look great, but stick with 15x7s on the front, I had 235/60s on the front and with 8" rims I had trouble lowering it as much as I wanted.  No problem with the 7" rims, you can actually put 245/60s on it with the stock 6.5" or 7" wide rims.   IMHO, 245/60s are too narrow for the rear and 225s are too narrow for the front, the 255 and 235/245 look good on it.
The Magnum 500s  are $139 each at Summit, Center caps are $37.12 at Wheel Vintiques, Cap retainers were $12.39 each at WV and $7.38 at Summit I think.    With a set of 235 and 255/60/15 BFG TA tires, the total came to $1,220, mounted and balanced at a local shop.
If you can get some huge spacers, you can run Cheap 17" mustang wheels on it.  They'll fit the rear, but will need at least an 1" spacer in the front.
I've personally gone back and forth on the subject of big rims (17-20") vs. staying with 15".   As far as I could find, you can't get raised white letter tires for anything bigger than a 15" rim.   I like them on these cars, they just look right.
I thought I'd just step up to 17", but to get the same size wheel I have now (28" in rear) and fill up the wheelwell, you still end up with a 50 series tire and can't get RWL.   It just doen't look right to me having that wide blackwall tire.
I think that if your going to go to anything bigger then a 15, you really need to step up to a 18 in front and 20 in rear to make it look right and have low profile tires.   A lot of guys are going with 18s and 17s, but unless you slam it and limit where you drive, it still does't fill the wheelwells very good.  My buddy Brent just got his car out of the shop and has 18s and 20s, and it looks just right at the stock ride height and no rubbing.  He has a thread on Member Restoration Projects with his tire/rim specs and lots of pictures if your interested, look under EvilTwinATX.
Good luck, let us know what you end up with.
Chris
Austin, Tx
« Last Edit: August 01, 2008 - 12:13:30 PM by PlumCrazyChris »
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
68 Barracuda (sold it too)
www.mopar.org
Offline HP2
« Reply #189 on: August 06, 2008 - 10:45:43 PM »
Test fit a different combo under the car recently, thought I'd pass along the info.
295/65x15 BFG Drag Radial on a 15x8 Cragar Dragstar with 4.5 backspace. Car has zero arch springs in the stock location, so it sits a bit lower than most.
Nice rake, pro street lite kind of look.
Offline HP2
« Reply #190 on: August 06, 2008 - 10:49:22 PM »
Dimensional specs for this combo are 29" diameter, 12" section width, 10" tread width. Fit is plenty tight everywhere, but fits. I've got about 3/8" to the fender lip without a rolled edge. I've got a 1/4" from the sidewall to the rear segment of the leaf spring. A 4.25 backspace might fit a bit better with a rolled lip, or a 1/8" space with a 4.5 backspace.
Offline Roppa440
« Reply #191 on: August 12, 2008 - 07:40:04 AM »
I tried 295/50/15s on 15x8 inch wheels with 4.5 backspace on the rear of my 1970 Challenger R/T.
I found the tyre was dangerously close to the leaf spring. Only about a quarter inch clearance.
I also think that a radial tyre that wide on an 8-inch wheel is too much. Radial sidewalls are designed to work in a vertical plane.
The whole thing looked pretty silly to me so moved the springs in on offset hangers and fitted the tyres on 15x10 wheels with 5.5-inch backspace instead.
Much better! :thumbsup:
I fitted the 15x8s to the front with 245/60/15s. These work out the same diameter as the rear tyres.
Dave
1970 Challenger R/T
Offline Haney
« Reply #192 on: August 14, 2008 - 08:43:29 AM »
15x7 4"BS - 245/60R/15
I went safe and conservative....
That is an AWESOME LOOKING Cuda!
1969 Barracuda Coupe, 340, 4-speed
Offline IMNCARN82
  • LeDZeP
« Reply #193 on: September 07, 2008 - 11:39:19 AM »
Thought i posted this in here... Couldn't find it. Here they are again.
Vintage wheel works V48 wheels
Front: 17 X 8, 4.5" backspacing   245/45 tires
Rear:  17 X 9, 5.0" backspacing   275/40 tires
Alterkation RMS front end,QA1 coils.
SS springs,upper perch holes,KYB's
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline the_engineers
« Reply #194 on: October 05, 2008 - 10:59:45 PM »
235/40/18 18 x 8.5 AZA Z-08 35 mm offset.  Had to add 1" wheel adapter from wheeladapters.com
275/40 on 18 x 9.5 AZA Z-08 35 mm offset.  Had to use Mopar Offset Shackles Kit.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
