Here's Dr.Diff's E-Body 1" offset hangar kit; using a motorcycle jack to install a 1968 B-body 8 3/4" housing. I also snagged the lightened spool from him ($85) on Ebay. Now, the 275-60-15 (10.5" Section width) Kelly radials leave 1.3" room @ the leaf. The Hoosier Drag (29x10x15") slicks on 8"x15"Weld with 4.5" back space, are 11.9" wide and will leave .6" room @ the rear leaf. But once you let the car's weight onto the slicks they fatten to leave only .3" to .5", so the passenger side needed the 5/16" spacer. This loaded carrier is 60 Lbs., stock housing is 40#, the axles are 20# each with 3" Mopar Perf. studs, total 140#s plus the brakes. Moser's housing's 60# bare. I went for less weight on this one, with the 741/ 3.91 ratio. Front tires are 215-70-14" on old 6"slots for now.
