Author Topic: Neutral Safety Switch Connector  (Read 1269 times)
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
« on: March 29, 2006 - 08:49:19 PM »
The guys who put my motor back in for me attached my 3 wires to my neutral safety switch, but without the connector.  Instead, they just crimped them on, can you believe it?
I went to O'Reilly's, looking for the connector, and they can order the switch, but not with the connector.  Where do you go to buy a new connector for your neutral safety switch, without buying an entire harness?  Thanks.
Re: Neutral Safety Switch Connector
« Reply #1 on: March 29, 2006 - 09:45:34 PM »
I just get a new harness & plug from Evans wiring
Offline ShelbyDogg
« Reply #2 on: March 30, 2006 - 08:16:15 AM »
If you're cheap like me. Get one from a junk yard and splice the wires onto your old harness with solder and heat shrink.   The 3 pin switch grounds the middle pin for your Park/Neutral starter solenoid and shorts the outer 2 pins together for your reverse lights.
« Reply #3 on: March 30, 2006 - 04:17:11 PM »
the old ones are generally hardened & shrunk from heat & often will not stay in place anymore
Offline zerfetzen
« Reply #4 on: March 30, 2006 - 09:11:07 PM »
That'll do it.  I'm buying the whole harness from Evans wiring for $33, though he said he had the connector for about $15.  Done deal, new harness and no worries.  Thanks for the info guys.
Offline PlumCrazy
« Reply #5 on: March 31, 2006 - 11:42:47 AM »
I just had to do the same, paid 29.00 thru Year One.  Lot easier than messing with the old stuff.
