Author Topic: help with master cylider  (Read 676 times)
Offline 70 340
« on: March 30, 2006 - 06:26:12 PM »
Changed from drum manual,? to disk manual.The master cylinder I bought is for power brakes.
Is there any problem with that?If it is alright do you still use the rubber sleeve that goes on
the push rod or do I have to buy a cylinder for a manual disk car?
Offline hemi71
Re: help with master cylider
« Reply #1 on: March 30, 2006 - 09:19:56 PM »
I'm pretty sure that it's the same master cylinder for manual or power disc brakes. Just dont try using a drum brake master on discs...not enough capacity in drum masters to actuate the calipers reliably.
« Last Edit: May 31, 2006 - 02:35:31 PM by Rev-It-Up »
« Reply #2 on: March 31, 2006 - 12:10:15 AM »
the power brake master will work fine IF it is a power disc master so that it doesn`t have the residual pressure valve in it
