Author Topic: 318 to 440  (Read 1224 times)
Offline Pentastar Pete
318 to 440
« on: March 31, 2006 - 06:24:54 PM »
I have a 74 Challenger 318.
I have a 440 complete. Besides the transmission, is there anything else I need to replace to make this work????
or is there any front end parts that would need to be replaced????
Thanks
74 Rallye Challenger
73 Rallye Challenger
68 Charger RT
Offline Stacked440
Re: 318 to 440
« Reply #1 on: March 31, 2006 - 07:46:29 PM »
It would have a small block K frame in it, and the torsion bars are larger on big block cars i beleive.  other than that i dont think so.
-Kyle-
Offline KellysCuda aircard
  • Its good to be blown
Re: 318 to 440
« Reply #2 on: March 31, 2006 - 08:25:04 PM »
You need motor mounts.
Offline 4Cruizn
  • HEMI FISH
Re: 318 to 440
« Reply #3 on: March 31, 2006 - 10:56:08 PM »
The trans will work, just need a different bell housing.    :cheers:
Re: 318 to 440
« Reply #4 on: April 01, 2006 - 01:40:43 AM »
just to clarify the K frame is the same , you will need big block mounts , a bigger rad , & .96 torsion bars would be a good idea , the auto trannys need to have the big block 727 case to work , the 4 spd just need a big block belhousing , the flywheel & clutch & trans can be used , if the 440 is a cast crank the flywheel would need to be balanced & you will have to drill a hole into the rear of the crank to clear the 4 spd input shaft & use the Dakota pilot bearing
Re: 318 to 440
« Reply #5 on: April 01, 2006 - 12:15:17 PM »
This is step by step help. Just what I needed.
Thanks Chryco.
68 Charger RT
Offline asm74
Re: 318 to 440
« Reply #6 on: April 01, 2006 - 12:50:55 PM »
He wouldnt need a new drive shaft and/or diff  I have a 73 challenger that Im thinking about bumping to a big block, and Ive been wondering wether the original drive shaft and the 8.75 diff could handle it....
73 Challenger
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
Re: 318 to 440
« Reply #7 on: April 01, 2006 - 11:05:51 PM »
You might want to get the bigger 3/8 fuel line and sending unit, 5/16 should be what you have for the 318.  The only other thing I can think is they recommend different leaf springs, assuming yours are stock, and I'm sure stiffer shocks.
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
Re: 318 to 440
« Reply #8 on: April 02, 2006 - 08:18:44 AM »
You probably will need to modify your driveshaft length.  I did the same swap, except with a 340/AT car and the 727 for an RB that I used had a longer overall length. You'll need to get an 8-3/4 or Dana 60 rear under it if you want it to survive. Mine rides well with the stock .90 T-bars, but I plan on going to the .96" as Chryco Psycho suggests.
Also swap out the fuel sending unit to the 3/8" and run larger fuel lines.  With 5/16" fuel starvation is a definite problem at WOT.  You'll start running out about 2-3 seconds into 2nd gear. Right about the time speed starts to get interesting. :naughty:
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
Offline 71383bee
Re: 318 to 440
« Reply #9 on: April 03, 2006 - 09:01:08 AM »
While your at it don't forget to modify the brakes... 4 wheel drums is a PITA for stopping power even in a 3teen car.  Of course disregard if you have discs.
As sugested you will also need a beefier rear end.  Prefer the 8 3/4 for versatility.
71 - 383 FC7 Super Bee
Offline MWILSON904
Re: 318 to 440
« Reply #10 on: April 30, 2006 - 08:01:20 PM »
I'm basicall asking the same question 318 to 383bb, for me it looks like I need a new radiator and figure out how/where to hang the power steering pump.
Good Luck, Mike
Re: 318 to 440
« Reply #11 on: May 02, 2006 - 02:34:08 PM »
I never  had to change my drive shaft on my swap, 318 to 440, rear was fine to...8.75, but i did change the rad to an aluminum, and fatter tires and.... :drool:
« Last Edit: May 20, 2006 - 10:06:27 PM by Rev-It-Up »
Offline crcarch
Re: 318 to 440
« Reply #12 on: May 02, 2006 - 03:02:01 PM »
Apparently 727 trannys had two tail lengths.  The one I took off a '70 GTX was longer than the original 727 that was in my '73 340 car, so I had to shorten the driveshaft.  It's easy enough to determine.  The answer is just a tape measure away.
