Author Topic: Surface Rust  (Read 652 times)
Offline Srobinson4
Surface Rust
« on: March 31, 2006 - 07:41:31 PM »
I know this is a nubie question but what is the best way to clean surface rust off of metal to wit a vintage air cleaner.  Once the job is done should I protect it with any substance before it is painted?  Thanks for all of your help.
SRR
Offline Steve
  • I Love Welding!
Re: Surface Rust
« Reply #1 on: March 31, 2006 - 09:36:44 PM »
Light surface rust can be taken off with steel wool, wire brush, or wire wheel. If you have a blast cabinet, glass beads or aluminum oxide will work. Phosphoric acid works good, too, as does Navel Jelly. If you are refinishing a painted air cleaner, strip all paint and rust off, prime with a good epoxy primer, and paint. If it's a chrome air cleaner, you can try glass beads or fine steel wool. If those don't do the trick, you'll have to send it out to get rechromed.
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
Re: Surface Rust
« Reply #2 on: March 31, 2006 - 11:33:48 PM »
emory cloth is good also (sand paper for metal). Comes in rolls.
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
