Author Topic: Just got home from some drag racin. my 318 pulled a 14.3  (Read 3836 times)
Offline GoodysGotaCuda
« on: April 01, 2006 - 03:35:39 AM »
Ended up making three passes tonight due to how many cars were there. I was only allowed to run my radials because its a 'street night' or w/e so i cudant run my mickey t's  :villagers:
anyyway. So in its full street trim, as i drive it daily, first run was a 14.6 - spun a lot, second run they didnt record it or something...so i got no time , and the last run i got a best of 14.3 @ 95mph outta the ol 318. I'm not crazy about that number, but we've gotta couple things we can still tinker with.
She ran hard tonight  318 put out some decent numbers, but im stickin to my guns saying i can get a 13sec slip. ive been saying that since i built the motor, and im not toooooooooo far away.
see attached, im in the left lane.
well.....how'd i do for my 2nd time racin? Last time i went i gotta 15.0 at 93mph
-Goody  :cooldancing:
hopefully my buddy took a few pics, so i wont get the
 :useless:
smilie  :rofl:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline n9671x2
  • I love YaBB 1 Gold!
Re: Just got home from some drag racin. my 318 pulled a 14.3
« Reply #1 on: April 01, 2006 - 05:59:17 AM »
Very impressive!!!   Anyone who has never been to the track will always think their car will run 12s, not the case at all.   :wow:
Offline Choppintime
« Reply #2 on: April 01, 2006 - 06:14:21 AM »
Get that car to hook and you'll slice off some 1/10ths. Haven't raced at the track in a couple years, miss the feeling.
Offline BB73Challenger
« Reply #3 on: April 01, 2006 - 07:03:59 AM »
I agree!!
The track or even a dyno is a VERY humbeling place.
Very good time I think, 13 seconds is not far, that's for sure.   :thumbsup:
Jeff from Cleveland, Ohio
Offline cuda
  • 1970 340 Cuda, pistol grip 4 speed,3:91 sure grip
« Reply #4 on: April 01, 2006 - 07:48:35 AM »
That is a great # for a 318. Im not sure my 340 would get that. Nice job.  :burnout: :burnout:
Offline hemi71
« Reply #5 on: April 01, 2006 - 09:29:49 AM »
Goody, thats pretty good for what i remember to be a mildly modded 318. What rear gear are you running? 13's are just a bit away, I think with tinkering with it, you'll get it.
 :thumbsup:
[attachment deleted by admin]
« Reply #6 on: April 01, 2006 - 10:26:04 AM »
 :thumbsup:
thanks for all the comments guys  :dogpile: it was as i drive it daily. They wouldnt lemme run my slicks at 'street night' because they arent street legal  :villagers: im aquiring some drag radials for my next outing. I have a few things up my sleeve to mess with  :cooldancing:
1976 Dodge Warlock
Offline Street_Challenged73
« Reply #7 on: April 01, 2006 - 11:54:31 AM »
Not bad at all for a 318 Goody!  I'm sure you'll be able to tap into the 13 second range the next time out, assuming you'll be able to use the slicks. :wave:
« Reply #8 on: April 01, 2006 - 11:57:48 AM »
sure hope so, if not on the slicks a local buddy is giving me some hardly used 275/60/15 bfg drag radials that should do the trick  :cooldancing: next race is the 26th i believe. should have the d/rs, line lock in so i can get some decent heat, and some tuning...hopefully get it where i want it  :jumping:
1976 Dodge Warlock
Offline EVIL72
« Reply #9 on: April 01, 2006 - 12:27:07 PM »
 Not bad numbers at all for street trim and a 318!
 Do you have your engine, stall, gear and suspension specs posted on here somewhere, maybe one of us can give ya a few more ideas on getting even better times.
 Good Job, I can't wait until I can start running mine.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
« Reply #10 on: April 01, 2006 - 12:38:43 PM »
Its all posted on my site. goodysgotacuda.com
rundown pretty much is
318 + .030
Comp cam, hyd, .480lift 280 dur
j-heads, 2.02s fresh 3angle valve job - 9.7:1 cr
peformer rpm intake
650cfm eddie thunder avs carb
MSD 6a/wires/coil
headers - was ran with open cutouts
rebuilt 904
3000rpm stall
transgo tf-2 shift kit
low gear set
8 3/4"
rebuild clutch sg
3.91s
 :dogpile:
1976 Dodge Warlock
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #11 on: April 01, 2006 - 05:36:29 PM »
Some stickies and some tuning might get you a 13,pretty stout for a 318 e-body.I`ve been trying to get a 12 out of my 340 for the last few years with no luck,stuck in the low-mid 13`s.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Carlwalski
« Reply #12 on: April 01, 2006 - 05:40:02 PM »
Not "too" bad for a 318. I've been seeing the 265HEMI /6 cars from Aussie lately posting 14.3 second 1/4's with not too many mods. I would have thought a 318 with those mods would have run 13's with a little more ease.
Good effort none the less mate.  :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline EVIL72
« Reply #13 on: April 01, 2006 - 06:37:24 PM »
 Here's a cheap trick I found on another site, I haven't tried it out yet, but worth a try
 install a field cutout switch to turn off alternator when making pass. worth 1 mph and .08. Easy..break the green wire and loop wire to 3 amp. switch under dash. burn out and pre-stage, then turn off alternator make pass, flip on at lights and full charge before pits. Makes just about one car length in quarter.
ROB
Alaskan_TA
« Reply #14 on: April 01, 2006 - 08:42:09 PM »
Very respectible! The 340-6 was road tested at 14 seconds at 100 MPH when new, I bet you can hit that with good traction.  :cheers:
Best of luck at the next outing Mike, keep us posted.  :thumbsup:
Barry
