Author Topic: Just got home from some drag racin. my 318 pulled a 14.3  (Read 3834 times)
Offline GoodysGotaCuda
Re: Just got home from some drag racin. my 318 pulled a 14.3
« Reply #15 on: April 02, 2006 - 12:22:07 AM »
Here's a cheap trick I found on another site, I haven't tried it out yet, but worth a try
 install a field cutout switch to turn off alternator when making pass. worth 1 mph and .08. Easy..break the green wire and loop wire to 3 amp. switch under dash. burn out and pre-stage, then turn off alternator make pass, flip on at lights and full charge before pits. Makes just about one car length in quarter.
Very interesting. ill consider that  :bigshades:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #16 on: April 02, 2006 - 04:59:06 AM »
There are plenty of tricks to lower your et,loosen sway bar,loosen ps belt,remove spare tire etc. but I prefer to run mine right off the street to give me a real number of how my car performs.The only thing I do is drop the rear tire pressure for traction and consistent launches.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #17 on: April 03, 2006 - 07:06:27 PM »
Way to go Goody!  Not bad, not bad at all.  You will be where you wanna be in no time!
« Reply #18 on: April 03, 2006 - 09:40:25 PM »
Got a couple pics a friend snapped. Of course i just found out next time i go ill needa helmet and a driveshaft loop  :eek4:
1976 Dodge Warlock
Offline EVIL72
« Reply #19 on: April 03, 2006 - 11:36:52 PM »
 Goody you ever tried running a Holley Double pumper on your car? Maybe you got a friend that has a 650DP laying around you could borrow?
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
« Reply #20 on: April 04, 2006 - 12:07:08 AM »
Nope haven't really considered changing carbs. I bought my eddie new late last year and i love it. I may be giving up a little e/t because of it, but daily driving comes before time slips  :biggrin:. I much rather have my eddie on there  :thumbsup:. I know you aren't talking keeping it on there, but for some reason I seem to be set on not changing carbs  :rofl: :screwy:
1976 Dodge Warlock
« Reply #21 on: April 04, 2006 - 12:07:52 AM »
oh and the d/a at the track that night was 3200ft  :eek4: 'corrected' for sealevel is a 13.8  :cooldancing:
1976 Dodge Warlock
Offline Andrew
« Reply #22 on: April 04, 2006 - 02:31:15 AM »
Not "too" bad for a 318. I've been seeing the 265HEMI /6 cars from Aussie lately posting 14.3 second 1/4's with not too many mods. I would have thought a 318 with those mods would have run 13's with a little more ease.
Good effort none the less mate.  :cheers:
That was the 265 hemi 6pak, the non-sixpak cars ran the standing quarter in under 16 seconds (dont know the exact figure)
The aussie chargers were probably lighter too.
Offline Carlwalski
« Reply #23 on: April 04, 2006 - 02:42:23 AM »
Andrew...that's my piont...either engine is a 6 Cylinder..  :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 74MOPAR
« Reply #24 on: April 04, 2006 - 02:43:34 AM »
Very impressive!!!   Anyone who has never been to the track will always think their car will run 12s, not the case at all.   :wow:
 Ain't that the truth !
 The Aussie cars must be lighter. I have seen the two side by side and the American Cuda sure looks larger.
 Nice times !!
74 'Cuda + 73 Charger Rally + $$ + assembly= Noble M400
 03 Ram Hemi 4x4
 78 Aspen Super Coupe
Offline Carlwalski
« Reply #25 on: April 04, 2006 - 02:44:43 AM »
 Nice times !!
They should be...I'll see if I can find some weights.... :cheers:
Offline Andrew
« Reply #26 on: April 04, 2006 - 02:53:46 AM »
Yep, its a 6.
Offline Robb
« Reply #27 on: April 04, 2006 - 10:52:52 AM »
that import didnt beat you did it ?
seriously, nice job.   keep having fun.
as someone else mentioned, youre getting to the point where its all the little things combined, that start making the big difference.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
« Reply #28 on: April 04, 2006 - 11:07:44 AM »
Good job, I can't wait to see how much it improves.  I'm a fan of your Cuda because it's so close to mine in terms of build, except I'm still in the fixing repairs stage, so it'll be a while before I take it to the track...and after I switch from 2.76's to 4.10's.  At any rate, cheers and keep us posted.
Offline Blackcuda
« Reply #29 on: April 04, 2006 - 11:27:46 AM »
That's not bad at all for a 318, if you can get your 60' time down to 2.00 or under with some drag radials you could be in the mid 13's. A nice little 100 shot will put you in the 12's for sure.
