Author Topic: My projects  (Read 2227 times)
Offline cuda340shaker
Re: My projects
« Reply #15 on: April 03, 2006 - 07:36:06 PM »
Hi, looks good! What backspacing do you have? 9.5" is a quite a lot if you are using origal e-body rear end. Tire size?
The back spacing on the rear is about 6 1/2 inches, which is actually not enough. The back lip rubs the leaf spring, but not too bad... so i'm either gonna get a 1/2 inch hub centric spacer, or just get the 1 inch offset shackle kit from Mancini Raciing, which is probably what I'll do since it will be safer with the amount of power I plan on making. The wheel/tire fit in the well perfectly. Oh yeah, the tire is a 265/35/18 rear and 235/45/18 front.
