Author Topic: EXHAUST QUESTION: Dumping Exhaust just after mufflers?  (Read 1696 times)
Offline 2000gt
« on: April 02, 2006 - 07:59:32 PM »
Hey guys, I have been struggling with something for a while now on my cuda.  I am wanting to go with an AAR clone, however I am not a fan of the AAR side pipes.  I also am running full frame connectors and Caltrack bars, both of which I think would interfere with the side exhaust.  Further more my car will be lower than stock - another stumbling block to running side exhaust.  However, even though I love the look of the rear exhaust through thte valence I don't think it suits an AAR.  So I was thinking of just dumping the exhaust after the mufflers.  Can this cause any harm to the car or the occupants?  Anyone out there had good or bad luck with this?  Thanks for the input guys.  Tyler
Re: EXHAUST QUESTION: Dumping Exhaust just after mufflers?
« Reply #1 on: April 02, 2006 - 10:58:53 PM »
in most cases this is fine , if oyu have any leaks in the rear body though it can draw exhaust into the car through the trunk
Offline 2000gt
« Reply #2 on: April 03, 2006 - 08:26:04 PM »
Well, I plan to seal up the trunk (and the whole car) well before it goes into paint.  Does anyone have any pictures of their dumps?
Offline RusTy/SE
  • Just havin' fun
« Reply #3 on: April 03, 2006 - 09:55:58 PM »
1967 Coronet R/T...
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline hemi71
« Reply #4 on: April 04, 2006 - 06:14:15 AM »
Check your area's vechicle inspection laws (if you have any). In the state of PA, that type of exhaust is illegal. The exhaust must exit at the rear of the car, unless it's factory equipped with side exit exhaust, then it's OK to exit at the side. In no instance is it legal in PA for the exhaust to exit under the passenger compartment of the vechicle.
« Last Edit: April 04, 2006 - 06:15:48 AM by hemi71 »
Offline dawgs 73
« Reply #5 on: April 04, 2006 - 04:49:52 PM »
Strict inspections in Missouri require the exit at the rear of the car too
RedLine
« Reply #6 on: April 13, 2006 - 04:38:59 PM »
OR....   you could go with a selectable approach like we did  - forward OR rear --  using electric cutouts
Offline Grancoupe
« Reply #7 on: April 19, 2006 - 04:02:45 PM »
Bad idea if your car isn't sealed really well. Inspection will be a problem in alot of states.
