Author Topic: Steering wheel lock plate removal.  (Read 2719 times)
Offline Cuda Cody
  • Vancouver, WA
« on: April 04, 2006 - 12:49:04 AM »
Is there any easy way to remove the steering wheel lock plate with out the special tool?   Here some pictures of the plate and the tool they say to use.
Offline Cuda Cody
  • Vancouver, WA
Re: Steering wheel lock plate removal.
« Reply #1 on: April 04, 2006 - 12:49:53 AM »
The year one tool doesn't look anything like it!
http://www.yearone.com/images/parts/t0_t9/t59.jpg
Offline Mopar73340
« Reply #2 on: April 04, 2006 - 01:48:27 PM »
Use a screwdriver to move the plate and expose the pin, then support the shaft and drive it out with a punch.
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: April 04, 2006 - 01:52:09 PM »
Me too!   :bigsmile:
Offline Cuda Cody
  • Vancouver, WA
« Reply #4 on: April 04, 2006 - 08:29:21 PM »
You guys rock :ylsuper:
Thanks  :thumbsup:
Offline ShelbyDogg
« Reply #5 on: April 04, 2006 - 09:57:31 PM »
Cody,
That tool from year one is for the GM style locking plate that sits on top of the turn signal switch. It has to be held down while a little wire retainer is either removed or installed.  Mopars used GM tilt type columns in the Cordoba. Which is the one I put in my '70 Challenger. If you ever had to take one of those off,  it's a real bear to put it back on. I found that a piece of 1/2 conduit and the Nut is enough to put it back together without that tool.
« Reply #6 on: April 05, 2006 - 01:10:46 AM »
I agree , virtually any tilt Mopar column is a GM column, & the tool above is for those
