Author Topic: what lubricant do you use in your tremec 5 speed  (Read 1857 times)
Offline hemi71
« on: April 04, 2006 - 08:08:54 PM »
Getting ready to get the cuda on the road, need to add some lube to the trans. What is the recommended lube oil?
[attachment deleted by admin]
Offline Mopar73340
Re: what lubricant do you use in your tremec 5 speed
« Reply #1 on: April 05, 2006 - 05:03:24 PM »
GM Syncromesh is what Keisler recommended for the Tremec 5-spd if I wanted my warranty to be good so that is what I used.
Offline hemi71
« Reply #2 on: April 05, 2006 - 07:05:28 PM »
Thanks 73340!
« Last Edit: April 27, 2006 - 05:27:17 PM by Rev-It-Up »
Offline Mopar73340
« Reply #3 on: April 06, 2006 - 02:10:10 PM »
Looks nice hemi71. That fluid is about $12/quart at the GM dealer.
Offline Robb
« Reply #4 on: April 07, 2006 - 04:17:54 PM »
dealer was only place I could find it
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline hemi71
« Reply #5 on: April 08, 2006 - 01:20:49 PM »
I got 4 qts at NAPA, $6.45 a quart. Turns out the trans was full anyway, and it has syncromesh in it, so now i have a nice supply if i ever need it.
 :thumbsup:
Offline Mopar73340
« Reply #6 on: April 08, 2006 - 05:32:01 PM »
Glad you were able to find it for less than 12, NAPA near me didn't have any.  :thumbsup:
Offline madness
« Reply #7 on: April 08, 2006 - 10:24:28 PM »
they say to put 3 qts in i put it in before i put the trans in the car after it was installed i pulled the fill cap on the side of trans it was pouring out maybe 3 qts is to much should be even with fill hole right?????
Offline Mopar73340
« Reply #8 on: April 09, 2006 - 06:32:22 AM »
If I remember correctly mine took about 2 3/4 quarts to fill.
Offline Robb
« Reply #9 on: April 09, 2006 - 11:26:14 AM »
same here, and my NAPA didnt have it either ?   They had something that was close, but still wasnt the right stuff, tried selling me Royal Purple.
Thats kind of odd that it came with Fluid already in it ?
Offline GreenFish
« Reply #10 on: April 10, 2006 - 08:31:15 PM »
mine was just shy of 3 qts also, i used the GM stuff, i wonder if synthetic would be better? Im leaving whats in it there at least unitil i have a reason to drain it.
