This may be a dumb question, but here goes anyway.
I just started to put the all of the wiring back into my car and I decided to make sure the starter worked.
Currently there is no motor in the car.
I have a cable going from the battery, straight to the large bolt on the starter.
Also I have a wire coming from the relay on the fender to the small bolt on the starter.
I tried to turn the key and all I hear is a clicking noise from the relay, then I thought that starter was not grounded due to the starter not being attached to the motor.
So I ran a wire from the battery (Neg. side) straight to starter and used one of the bolts which hold the body of the starter to the case.
Now I hear a clicking noise then a buzzing noise from the relay.
Not sure if I have the wiring wrong or the relay / starter is bad?
I have also check that the wire coming from the relay to the starter has power when the key is turned.
