Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Starter
« previous
next »
Print
Pages:
1
2
3
Author
Topic: Starter (Read 2911 times)
Topcat
C-C.com Expert
Member since 9/16/04
Re: Starter
Reply #15 on:
June 21, 2009 - 11:09:13 AM »
I usually take my starters or alternators in question to CSK auto. (Kragen)
Many of the stores have a testing unit in their stores.
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: Starter
Reply #16 on:
June 21, 2009 - 01:33:30 PM »
Quote from: JimL on June 21, 2009 - 09:48:45 AM
How do I know if I have a bad starter relay?
With a screwdriver short the terminals, if it cranks the relay is bad if not the problem lies elsewhere.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
JimL
Jr. Member
Re: Starter
Reply #17 on:
June 21, 2009 - 09:20:51 PM »
Thanks for the picture of starter relay.It was very clear.I checked mine out and it does the same thing as turning the key.It just makes a clicking sound from the starter.So I guess it isn't the relay.
Logged
JimL
Jr. Member
Re: Starter
Reply #18 on:
June 21, 2009 - 09:34:45 PM »
Battery cables seem to be good.I checked them out today and cleaned them at each end.I checked the wires on the relay and on the starter with a voltmeter and had about 12.72 volts on both.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Starter
Reply #19 on:
June 22, 2009 - 01:39:54 PM »
Starter solinoid must be the issue
Logged
JimL
Jr. Member
Re: Starter
Reply #20 on:
June 23, 2009 - 08:31:51 PM »
I took the starter solinoid off and cleaned it up on the back of it and where it mounts to inner fender.Still all I get is a clicking sound from starter.It is also a new solinoid.I did notice that the starter gear gets stuck in the flywheel everytime I try to start it. I have to then move the flywheel just a little bit to let it release.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Starter
Reply #21 on:
June 25, 2009 - 01:32:13 AM »
loosen the starter bolts & twist the starter away from the ring gear until the starter will not jamb
Logged
JimL
Jr. Member
Re: Starter
Reply #22 on:
June 26, 2009 - 12:31:25 PM »
I turned the starter left and right but it still gets stuck.If I move the flywheel just a little it comes back out. I'm thinking it just does't have enough power to go in and out?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Starter
Reply #23 on:
June 28, 2009 - 03:14:20 AM »
if it sticks engaged there is only a spring to pull it back , the issue has to be either & oversize ring gear or the drive is oversize if it still jamb after moving the starter around
Logged
JimL
Jr. Member
Re: Starter
Reply #24 on:
June 28, 2009 - 10:50:11 AM »
Should the drive on the starter be greased or oiled so it would slide in and out easily?Right now it is dry and some kind of coating or paint is on it.When it goes into the ring gear it get stuck then I move the ring gear just a little and it comes right back out.Could it be possible that my ring gear is bad maybe bent or something? It was running last year and it just wouldn't start one day.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Starter
Reply #25 on:
June 29, 2009 - 02:30:18 AM »
I have never used any oil there , there has tp be an alignment issue , do you have another starer you can try out
Logged
Bullitt-
Permanent Resident
Re: Starter
Reply #26 on:
June 29, 2009 - 04:53:17 PM »
That black "paint" sounds like cooked on grease...I'd clean it off & lightly lube.
Logged
Huntsville, AL
JimL
Jr. Member
Re: Starter
Reply #27 on:
June 29, 2009 - 08:13:05 PM »
I changed the starter today with another high tork one and have the same results.Starter gear gets stuck on ring gear.I'm I suppose to have any volts comming off the smaller wire on the starter? There is none right now.
Logged
Bullitt-
Permanent Resident
Re: Starter
Reply #28 on:
June 29, 2009 - 11:40:33 PM »
Volts to the small wire are to energize the solenoid & internal starter switch, power should only be present when the ignition switch is in the start position. .... I think your main power cable from the battery to the starter has a problem.
Logged
Huntsville, AL
JimL
Jr. Member
Re: Starter
Reply #29 on:
June 30, 2009 - 09:16:17 AM »
Is there a way that I can drop the starter out but keep the cables attached and ground it some how to see if the starter will work that way?
Logged
Print
Pages:
1
2
3
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Starter
