Author Topic: 70 Cuda headliner bow problem  (Read 1265 times)
Offline 71340RT
« on: April 06, 2006 - 12:12:37 AM »
My 70 Cuda is only the 2nd headliner I have ever put in. ( My 71 Challenger RT being the first)> I can't seem to get the winkles out of the sides and have tried a hair dryer. Looking at it I wonder if the headliner might be sewn wrong as when I pull the front tight it puts wrinkles in the sides between the bows. I have tried to pull the side down and fasten them but the wrinkles never go away. I may take some pictures Thursday and post here. I'm not sure what the order of the 5 bows are as mine were out when I bought the car and no one marked there order. They are color coded so if some one knows the colors and order let me know what it is. I put them next to each other and it looked like they were all the same if I remember right except for one bow. If anyone has any ideas please let me know as my Challenger headliner turned out perfect.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline miketyler
    • www.miketyler.net
Re: 70 Cuda headliner bow problem
« Reply #1 on: April 06, 2006 - 05:00:33 AM »
Here you go:
http://www.restorick.com/tech/topic.asp?TOPIC_ID=46
On the wrinkle remover I found that a hair dryer just didnt cut it (and I had a big one)  :banghead:
I plopped down $10 at Harbor Freight for a dual temp heat gun and that thing kicks butt. BIG difference in performance and removes wrinkes quickly. I dont know if this will help but I used a circular motion starting outside and moving in towards the wrinkle.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline 71340RT
« Reply #2 on: April 09, 2006 - 09:51:35 PM »
Here you go:
Thanks for the advise. I have got it all installed and will know try the heat gun to see if I can get the wrinkles out.
