Author Topic: Tip of the Iceburg! Rust is a bad thing  (Read 1284 times)
Offline Steve
  • I Love Welding!
« on: April 08, 2006 - 01:46:26 PM »
Ok....so my original decklid was toast, which is not at all uncommon. I picked up a used decklid that seemed workable. As you can see in the first two pics, there were some rot holes, but no big deal, I'll just repair them.
So, I decide to cut a good section of skin off my original decklid and transplant that onto the decklid I plan to use. In the process, I cut off a section of skin and found pure evil under the skin. Problem here is that I can't get to all of the bracing without completely pulling the skin off. Well, sort of too late for that!
Bottom line: If you see rot holes, you are in for more than what meets the eye. In the case of decklids, small rot holes will also likely indicate that the areas of the decklid frame where the skin folds over will also be rotten. Looks like I'm going to order a reproduction lid!
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: Tip of the Iceburg! Rust is a bad thing
« Reply #1 on: April 10, 2006 - 09:05:01 AM »
Ouch!  Car cancer...it's a nasty disease!!
Offline Stacked440
« Reply #2 on: April 11, 2006 - 12:22:30 AM »
heh same thing happened to me when i took my car to blast, i knew there were a few holes in the trunk but after we blasted it, the trunk pans looked like swiss cheese!! :eek4:
-Kyle-
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: April 11, 2006 - 07:00:52 AM »
Yep the blaster hides nothing!!  I like when a car comes home from the blaster . . . you know exactly what you have to work with at that point!!   :cheers:
Offline outofcadence
« Reply #4 on: April 24, 2006 - 09:39:01 AM »
Rust always looks small at first and then you find out more damage under the body rot.  Looks like my deck lid when I pulled it off.  I had the same issue and decided it was easier to order a repro than
Offline RUSTY Cuda
  • One big step foward!
« Reply #5 on: April 24, 2006 - 05:50:41 PM »
Yep, went through that with the first hood, thats why I skinned the second one, even though it had no rot holes, it was still nasty in between there. did I mention I HATE RUST!
Rich.
Offline moparclown
« Reply #6 on: April 24, 2006 - 06:06:36 PM »
rust is nasty thing I know first hand
