Author Topic: Carpet underlayment  (Read 2209 times)
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
Carpet underlayment
« on: April 09, 2006 - 05:04:16 PM »
It seems that every auto TV show I've seen puts jute under the carpeting.  Can't seem to find any at the typical locales, (Home Depot, Lowe's, etc.)  The do have carpet underlayment made of foam, some of the more expensive stuff has Scotchguard treatment.
Is there a reason that you can't use this newere foam stuff?  Is the oldschool cotton stuff really better? Let me know what you think.
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
Offline chevyconvert
  • HvacMan
Re: Carpet underlayment
« Reply #1 on: April 09, 2006 - 05:41:51 PM »
Whenever I've bought molded carpet sets in the past, the jute backing was included & attached to the carpet's underside.
Eric
Bay Area California
Offline crcarch
« Reply #2 on: April 09, 2006 - 06:56:16 PM »
I have that, but I want additional padding under foot to make it a little more luxurious and to provide more sound dampening.
  • HvacMan
« Reply #3 on: April 09, 2006 - 07:51:56 PM »
Eric
Bay Area California
Offline crcarch
« Reply #4 on: April 09, 2006 - 08:24:05 PM »
Just padding.  I've already got Dynamat for sound and Reflectix for heat.
« Reply #5 on: April 10, 2006 - 06:02:41 AM »
I have found many uses for closed cell foam, 3/8"Black works well for padding I made kick panels from 3/8"Grey which is stiff. Knoxfoam has good price.
http://knoxfoam.com/cgi-bin/SoftCart.exe/closedcellfoam/closedcellfoam.htm?E+scstore
Offline crcarch
« Reply #6 on: April 10, 2006 - 06:58:27 AM »
So you've used the foam as a carpet underlayment without any problems?  How long ago?
« Reply #7 on: April 10, 2006 - 07:35:29 AM »
I have used as underlay, only been a couple of months. It is a little stiff but I was able to cut & get contours. It took a little more than one piece to do. Closed cell foam does not absorb moisture. If you have ever seen the higher end carpet padding used in houses, I believe this is a similar product.
Offline crcarch
« Reply #8 on: April 10, 2006 - 08:03:19 AM »
Good to know.  Thanks.
Offline 73EStroker
« Reply #9 on: April 10, 2006 - 12:53:09 PM »
Also remember if you are replacing the carpet keep the little backing pieces that fit into the floor rib dents. Hard to replace and they make the carpet look flat on the floor. I kept all of mine so when the carpet goes in I will have the factory look. Also I am going with the original cotton. If you cannot buy the cotton (believe it) my original stuff is still in great shape from 1973 - go figure.
Barry (Salmon Arm)
Offline crcarch
« Reply #10 on: April 10, 2006 - 11:08:26 PM »
I have never heard of backing pieces.  My original carpeting was destroyed when the car was flooded in 1985.  I don't remember seeing anything like that when the original carpet was removed, but it would make sense.
Offline falcon50flier
« Reply #11 on: April 12, 2006 - 11:30:40 AM »
Jute HOLDS heat and is about the worst for flame retardant properties. If you run headers it will help make your interior an oven. It doesn't do much as a sound deadener either compared to other modern materials (Dynamat and generic limp mass [1 lb sq ft] sheet). Residential carpet pad (either virgin foam or rebond) is not made to withstand heat, or to be a good sound deadener. If you go to trouble and expense to replace your carpet, spend a few extra $$ on the real deal.
See www.insulshield.net for a broad selection of materials. There's also Lizard Skin and similar spray ons, with both heat suppression and sound deadening formulations.
« Last Edit: April 15, 2006 - 08:53:53 AM by falcon50flier »
70 Challenger convertible
518 cid Hemi, TF727, 3.73 Dana 60
