my concern is the the front end geometery may be comprimised because of the difference with the two adjuster bolts. the front end is all new (torsion bars ,left on left side right on rightside,ball joints tie rods strut rods)Also when lowering the driver side the passenger side height was affeceted.I've done some research through my challenger service manual and it explains when strut rods and the front end hanger for the torsion bars(adjustment end)are installed,they should not be torqued untill ride height is set.the front end was put together months ago but i did not have my wheels to set the height till last weekend.so the front end was all torqued up before and the height had to come down 3 inches.I figured I could loosen the strut bars and torsion bar hanger,level out the adjusting bolts ,settle the car and then adjust the height (hopefully this time no problem) then torque everything down.
