Author Topic: dimmer switch replaced but wont work  (Read 860 times)
Offline 73 challenger 440
« on: April 11, 2006 - 07:53:03 PM »
I replaced the switch for my dash lights, I noticed there is a blue wire there thats not hooked up, it was like that when I removed the original.. what wires do I test to find out if there's juice?  how do I trouble shoot to solve the dash lights not working, they use to work, then one day they just stopped, so I replaced the switch, but still no lights.
Re: dimmer switch replaced but wont work
« Reply #1 on: April 12, 2006 - 12:40:01 AM »
have you checked the floor dimmer switch
« Reply #2 on: April 12, 2006 - 05:47:09 AM »
Looking at a 73 Dodge Service manual, It appears the incoming power is a black wire coming from the headlight switch to the LH (drivers side) terminal. RH terminal appears to be for dome lamp. Middle terminal is identified as E1-18T (no idea what color T represents) heads off to harness I guess to connect to cluster lamp wires which are Orange.
I looked up thru the dark abyss of my dash and it appears this center wire is DARK Blue. You should be able to ohm out to the lamps orange wire.  :smokin:
« Reply #3 on: April 13, 2006 - 06:43:52 PM »
well, I had to run a jumper wire from the middle connection to one of the wires on the end of the connector. now they work they just dont dim..
