Author Topic: 1973 Challenger Rallye complete running project TRADE FOR A OR B BODY  (Read 6736 times)
Offline 74chall
  • Mopar or No Car
1973 Dodge Challenger Rallye
 :bananasmi 9,500!!!!!!!!!!!!!! :bananasmi
Code Description
JH23 J = Dodge Challenger
H = High
23 = 2 Door Hardtop
G3B G = 318 150HP(net) or 170HP(net) 1-2BBL 8 CYL
3 = 1973
B = Dodge Main, Hamtramck, MI, USA
510430 Sequence Number '510430'
JH2 Paint Code: Black
247678 Order Number: 247678
JA5 Roof Type OR Color:  Dark Silver Poly
A6X Unknown At This Time
000 Full Door Panel
602 Unknown At This Time
E44 318-2 Barrel
D34 TorqueFlite Automatic Transmission
JA5 Dark Silver Poly
U Built to Specifications for USA Order
A57 Challenger / Charger - Ralleye
B41 Front Disc Brakes Some Yrs. Power
C16 Console w/ Buckets
C56 Bucket Seats 1972 up
H51 Single Air /w Heater
J54 Hood Insulating Pad
L25 Trunk Compartment Light
L31 Hood / Fender Mount Turn Signal
M08 Simluated Door / Fender Louvers
M21 Roof Drip Rail Moldings
N85 Tachometer
R35 AM / FM Multiplex Sterio
V6X Black Longitude Sports Stripe
26 26 in. Radiator
G36 Left Hand Remote, Right Hand Manual Outside Mirror
Drive Train:
Mid 80's roller 318 w/ 60k miles
Factory 4 barrel intake with a new holley vaccum secondaries electric choke carb.
headers, electronic ignition
727 transmission
8 3/4 with the good 489 series case
Steering and Suspension:
a57 package
Front and rear factory sway bars
Magnum 500's
Power front disc brakes
Power steering
Factory A/c with underhood componets still there
Interior:
Buckets and console(slap stick)
Seats have no rips,console has two screws put in the lid(console lock works great)
Head liner has a small rip on the c pillar, could use a carpet set. Door panels are nice.
Very nice factory rallye dash . hard to find rallye dash pieces are all there(wiring hooked up, A/c control assembly,light bar etc)
Very nice 3 speaker dash with multiplex stereo
BODY:
I'm going to try to describe the body to the best of my ability. The body could use a set of quater skins as they are bubbling up on the lower. You might be able to get away with just the lower patch panels. The trunk has two 2x2 spots  which need a small patch . No need to replace the whole pan for this. The hood hinge area needs to have the replacement patches yearone sells for them installed.  The driver floor has a 6x6 soft spot. Front windshield is cracked!  Thats the bad. The COWL IS ROCK SOLID,as are the frame rails, doors,trunk lid, floor pans except for the area mentioned, frame rails, Nice RT hood, fenders with rallye louvers etc. This is a project car, you do need to do some minor metal work to the areas i have mentioned .Far from a rot bucket . You can drive this car and work on it as you go. I have seen a ton of people take on huge project rust buckets and then get discouraged,loose motovation and give up on it.  You can do the hood hinge areas one weekend , the trunk patches another etc on your own time while still driving it. It's a complete car that you dont have to go hunting down all those hard to find mopar e body parts.
New inline tube fuel tank with 3/8 sending unit. Fuel gauge does work. Flip top Chrysler org. fuel door,dual sport racing mirrors, fender mounted turn signals,etc
Rear valance is bent up
Final evaluation:
Yes the car needs some work. I have the missing front window trim, the alternator, and also the a/c compressor that go with the car.
The trans could use a fluid change but it does go into gear and move the car around with no problems. Some minor things under the hood like installing a bracket for the coil, routing the wires ,etc a little better, but never the less a fun project to do. A rare car ,loaded with options, a fender tag , and clear NJ title. This is an EXCELLENT START,which will be worth a lot of money when restored. An excellent father/son project,Hopefully someone will do it right and drive it like these cars were meant to be driven,not sititng in a garage collecting dust!
located in south nj
manahawkinmx75@aol.com
« Last Edit: May 14, 2006 - 05:25:57 PM by 74chall »
Offline pink panther
Re: 1973 Challenger Rallye complete running project
« Reply #1 on: April 13, 2006 - 06:30:24 PM »
do you know where the car is located?
Offline ExCloud
« Reply #2 on: April 14, 2006 - 12:56:39 AM »
Do you have more pics?  Any rust that i am missing?
Offline miketyler
    • www.miketyler.net
« Reply #3 on: April 14, 2006 - 05:23:49 AM »
looks pretty good for $12K even if it does need quarters :wow:
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #4 on: May 03, 2006 - 06:34:04 PM »
where is the car located?
Offline 74chall
  • Mopar or No Car
« Reply #5 on: May 03, 2006 - 06:43:19 PM »
I'm in New Jersey
Offline 67 Ruda
« Reply #6 on: May 04, 2006 - 08:07:57 PM »
I guess you not interested in any trades like a 94 Mustang?
« Last Edit: May 04, 2006 - 08:36:35 PM by Rev-It-Up »
Offline 74chall
  • Mopar or No Car
« Reply #7 on: May 04, 2006 - 08:48:35 PM »
Not really, but thanks for the offer! Im really selling it to get space back. No room ! so another car wouldnt make sense.  :wave:
Offline EVIL72
« Reply #8 on: May 12, 2006 - 09:46:28 AM »
 Looks like a fair deal to me, I wish I had the cash I'd pick it up in a second.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline moper
« Reply #9 on: May 12, 2006 - 11:03:40 AM »
It looks fairly solid, as far as E bodies go. Personally, it's a non numbers matching 318 car that needs the body done. Nota  lot of work, but if you cant do it all yourself, you're looking at $10K worth of parts and body/paint, nevermind the "details", like rechroming and such. It's not a bad car, but the end reslt is not going to be worth the price to pay someone to do it. I think that's why you may not be generating the interest. If it was a 340 car, or a 70-71, you know you would have sold it for more by now. It's a fair price, just not a "deal" IMO.
That being said..You dotn want a Mustang, what would be a trade you'd be looking for?  :biggrin:
Offline MyMopar
« Reply #10 on: May 13, 2006 - 11:47:14 AM »
Boy I feel taken on the car that I bought.  I did spend a bit less but did drive much farther.  I'm going to say that $9500 is a deal regardless of what anyone else says.  Looks pretty good, except for the rust  :grinyes:
I'd buy it but 5 cars now my wife would kick me out!  :walkaway:
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Offline SirChandlr
Re: 1973 Challenger Rallye complete running project TRADE FOR A OR B BODY
« Reply #11 on: May 14, 2006 - 07:18:37 PM »
like a 73-74 b body?  i've got a 73 charger and a buddy of mines got a 74 runner clone I'm sure he'd trade in a beat. Both our cars are currently being prepared for paint and we could do any color you like.
Offline HookedOnMopars
  • MOPAR Maniac!
« Reply #12 on: May 14, 2006 - 10:15:45 PM »
Thought you were looking for a Chevy Drag Car roller?  What happened to Mopar or no Car?
Offline kmyles
« Reply #13 on: May 15, 2006 - 08:30:57 AM »
Would you be interested in a fully restored 1951 Dodge 2 door coupe?
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #14 on: May 15, 2006 - 04:28:31 PM »
How about a 70 Olds Cutlass with a 455?  I have a few crappy pics on this computer, I can get more if you are interested.  It is my hubby's car and we were talking to someone about selling it to them for 15,000.  If you like it maybe we can work someting out.
April
