Author Topic: McLeod street twin problem  (Read 860 times)
Offline yellow340
« on: April 14, 2006 - 12:05:09 AM »
Having a problem with my Street Twin clutch.   The clutch disk closest to the engine will not disengage while the other one will.
It all worked before but I had to pull the engine to replace the rear seal and now that it's all back together the clutch will not disengage any ideas on why before I take it apart again?
Re: McLeod street twin problem
« Reply #1 on: April 14, 2006 - 01:31:28 AM »
are the bolts holding the Pressure plate pinching the disc ? or is the disc in backwards ?
