Author Topic: msd ready to run help  (Read 897 times)
Offline Challenger1970
« on: April 15, 2006 - 10:36:43 AM »
72 challenger with a 360.I am putting an msd ready to run distributor.This eliminates the ignition control.Therefore would I still need a ballast resistor between the voltage regulator and the +side of coil/ignition switch wire (dodge wiring diagram). Also the msd instruction show the red distributor wire tied directly to 12v ignition and to the +side of coil via a ballast resistor.My question is to anyone who has run this distributoror has experience with it, does this sound correct and what value would the resistors be.thanks for any help
Re: msd ready to run help
« Reply #1 on: April 15, 2006 - 11:46:02 AM »
yes it sounds correct , the dist MUST have 12 v to operate properly & the coil needs to have the resistor to protect it , in most cases depending on what the coil Mfg specifies for it  , generally the balast with the lowest resisitance possible will be best & increase the spark power without burning up the coil itself
