Author Topic: Hemi torqueflite parts  (Read 4213 times)
« on: April 15, 2006 - 11:24:25 PM »
Today, while over at a friends house, He gave me some old A/T Mopar parts. One was the tail piece that bolts to the A/T. Thats the one the drive shaft goes into.  He told me they're from a Hemi Torgueflite. Also, I got a 4 gear planetary assy. from it. There are some more parts there besides to it. Are there any more parts to it that I should look for that are of value? The main case is gone. And now my camera is broken for right now until I get it fixed. So no pics right now unfortunately. Please tell me, what should I look for that might be important or worth salvaging from this pile of supposed Hemi Torgueflite parts. Thanks
Offline tactransman
Re: Hemi torqueflite parts
« Reply #1 on: April 16, 2006 - 03:52:49 AM »
The parts you have really are not that valuable. The parts in a hemi torqueflite that are valuable is the high gear drum and intermediate band that goes around it.Also the case (for numbers matching) :cheers:
Terry-tactransman
Union, Mo.
Offline Carlwalski
« Reply #2 on: April 16, 2006 - 09:00:14 AM »
How do you know if you have a "HEMI" TorqueFlite or a "Regular" TorqueFlite??  :dunno:
Are the HEMI trans the Heavy Duty D32 option on the Fender or...... ???
 :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #3 on: April 16, 2006 - 12:03:22 PM »
OK, Thanks. :cheers: So then I presume the main shaft doesn't have a different spline count like a 833 does.
But isn't a 4 gear planetary a desirable part to have on a rebuild/assembly? From what I what was told to me before, 4 gear planetarys were only inside HP A/T trans.
Offline tactransman
« Reply #4 on: April 17, 2006 - 07:47:37 AM »
:undercar:
The input shaft splines are different by year of transmission not by hemi or not. Pre-'67 -19 spline , '67 on 24 spline. The 4 gear planetary can be found in alot of transmissions(mostly big blocks) . I have a couple of Indy Motor race cars that are running 3 gear planetaries running 9.50's in the quarters and leave the starting line with 2 feet of air under the front tires and the three gear planetaries are holding up fine(I check them for freshing up every winter) :cooldancing:
Terry-tactransman
Union, Mo.
« Reply #5 on: April 17, 2006 - 08:30:26 AM »
Thanks again so much.  :cheers: Well, if anybody wants em cheap, let me know.
Offline Carlwalski
« Reply #6 on: April 17, 2006 - 02:31:05 PM »
 :cheers:
Ahhhhh,  :dupe: anyone know?  :clueless:
Offline tactransman
« Reply #7 on: April 17, 2006 - 03:26:18 PM »
There is a part number stamped on the case right above the trans pan rail by the shifter linkage . I don't know the part number for a "Hemi Torqueflite" but that is where it would be. If you take one apart you can tell by the insides. :wavingflag:
Terry-tactransman
Union, Mo.
« Reply #8 on: April 17, 2006 - 09:18:09 PM »
Hmmm, now ya got me thinkin.  This guy (idiot) took a Hemi torqueflite apart and built a whole new torqueflite out of all the parts. There is a very good chance he still has the case. And I'm sure if it really is a Hemi torqueflite, like he claims it may be for sale. So what would a Hemi torqueflite body be worth?
Offline Carlwalski
« Reply #9 on: April 17, 2006 - 09:38:53 PM »
Thanks mate, hopefully Joe (FY1) sees this thread and can help out with location and number reference.
Cheers.  :cheers:
