In '68 the "regular" vrs the "magnum" 440's were identical parts wise, save for the latter, got the addition of a hotter Cam, Valve Springs, Windage Tray, .001" smaller Crank sizes, exhaust manifolds, and Carb, as per application.
All '68 440's used a 2.02" Comp. Distance Piston, (.060" downhole), Flat-top, and 906 heads to yield an ACTUAL Compression Ratio around 9.8:1, even though ADVERTISED at 10:1.
Later '69 440 - 6 Pack Engines used a Flat-top Piston with 4 valve reliefs at a Comp. Distance of 2.06,(.020" downhole), for an ADVERTISED Comp. Ratio of 10.5:1, ACTUAL was more like 10.2-10.3:1.
All Engines used a "steel shim" type head gasket @ .022" thickness.
When Rebuilt, I'm guessing they used a composition style head gasket @ .042" thickness, that, and the heads being milled .010" would only offset the valves being sunk during regrinding, leads me to "GUESS" the actual compression of that engine in the 9.8:1 ballpark. Very nice street motor.
CAUTION; the actual 68-69 Piston with that Comp. Distance, lacking any Valve reliefs, doesn't accept much cam lift, be careful not to exceed .500" lift with future cam choices, lest your Valves will get "real friendly" with your Pistons !
The above, is the reason most aftermarket replacement Piston Manufacturers for years, only offered the 66-67 Piston Distance of "1.99"(.090" downhole), and 1.96"(1972-1978)(1.20" downhole), the latter being akin to a "popcorn" fart for Compression, and the 1.99 piece being inaccurately listed as the "10.1" piece, as it was, but only when using the older 66-67 closed chamber style heads.
Some Trivia;
The actual 68-69 2.06" Full Flat-Top Cast rebuilder Piston was NEVER offered by the aftermarket in oversize for rebuilding "Correct" 68-69 motors. All you guys who "THINK" you've got stock "Correct" rebuilt 10:1, 68-69 Engines using 906 heads, DON'T ! hence, why they don't perform as well as they did new, in case anyones wondering.
FC out.
