Author Topic: FACTORY INSPECTION MARKS, NUMBERS Etc. (anybody have experience with this?)  (Read 7742 times)
Offline AARudy
  • 1970 4-speed AAR---71 Cuda conv----70 Chall 440-6
I have read the Challenger/Barracuda restorer's guide, and it explains certain markings and colors, but does'nt get into too much detail about it. I want to puit them on my rear axle, differential, etc. I guess, I'm asking if there's anybody who can tell me what markings I need....are there stencils out there for them....and what kind of paint is it??? My AAR has a 8 3/4 with 3:91's and the code on my build sheet for the axle is 078. Supposedly the right side axle tube has this code stenciled in yellow....check out my reference pics so you know what I'm babbeling about.....I also see a circled X on the back o fthe differential too, made by a grease pencil or something....there's not much I have found that explains any of this...??? ??? ??? ??? my 4-speed trans also has light blue numbers that were stenciled from the factory (789) along with a white cross....do I have to hand make these stencils or are they out there??.......the yellow one below has a big F on it???  I'm lost...(as usual)
« Last Edit: April 26, 2006 - 11:16:31 AM by Rev-It-Up »
Offline 70Cuda
  • 70 Cuda 383 70 Challenger 440+6 71 Challenger 383
A version of the e-body fastener guide has some of this information in it and this guy was a judge at major shows too
http://www.mmcdetroit.com/
Offline FY1 RT SE
Not to rain on anyones parade, but all the pictures posted and most on the above referenced website are someones "interpretation" of what things should look like.  For example no front sway bars, tie/strut rod were ever painted at the factory.
The best example is to look and see how your car was done.  For every example you posted I can post an original example that is different.
The 789 is a reference to the part number 3410790.
« Last Edit: April 26, 2006 - 11:17:20 AM by Rev-It-Up »
Offline AARudy
thanks for your input and original pics. This is souch a touchy subject, I will worry about later on after I learn more.
Offline 41husk
I have a old mopar muscle somewere at home about 7 or 8 years old that goes over all the factory marks and even what paints and colors.  I will see if I can find the issue.  But the info is out there.
1969 Dodge Charger Daytona Clone 440/727
1970 Dodge Challenger Convertible 340/727
1977 Dodge D-700 Car Hauler 361/5spd
2009 Dodge Challenger SRT8 6.1/auto
Offline AARudy
Let me know... (i have plenty of time, so at your leisure!!)
any info sure helps! Thank you!
Rudy
Offline FY1Challenger
  • I'm a llama!
Rudy - like FY1RTSE says generally the rear axle assembly had:
(DD MM) or (DD-MM format) ex. 10 15 or 10-15 date code stamped on the center section (facing) bottom of left side flange
Three or four paint stripes on the bottom of the pumpkin indicating gear ratio and SG
Lft side axle tube has (DD MM) or (DD MM Letter) ex. 10 16 or 11 12 F date code located near center
Lft side axle tube has three digit part number taken from build sheet located near outer axle tube flange
Various markings on center of pumpkin ex. circle with X upside down "E" usually done w/grease pencil
Various marks located near torqued fasteners, ex. leaf spring U bolts, brake backing plate, pinion snuber bolts, etc.
Offline AARudy
Thank you, that explains a lot. I've never really talked to anybody that has done this...mostly cause I usualy dont crawl around looking under their car too long at a show. This is my first Mopar that I am restoring, so I'm glad you guys bare with me on all of my questions. The next car will be a lot easier!
Rudy
Offline cv70chall
  • 1970 Challenger
I'm in the same boat.
8.75 rear for my E Body that has 489 Case, 3:23 and Sure Grip. I want to install the correct markings but need to know exactly what and where.
Anything - help would be greatly appreciated!
Offline anlauto
There's no such thing as "correct" markings, no two rear ends left the factory identical.  :2cents:
There should be your three digit code on the left axle tube, gear ratio colour code across the bottom and the rest is up for grabs. :bananasmi
Offline Challenger in NC
Here are a couple more examples I found buried under years of grease and grime. Three digit yellow stencil but hard to read. No idea what the white marking or the circled symbol is.
Its a 3.91 suregrip, 489 case.
Offline 73440
http://s1302.photobucket.com/user/73440/slideshow/Axle
Some info on axle markings
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
