Author Topic: 383 stroker  (Read 1523 times)
Offline jc777
383 stroker
« on: April 17, 2006 - 07:49:15 PM »
73' Cuda 340
68' Charger
Offline Plum6Pak
  • Plum6Pak
Re: 383 stroker
« Reply #1 on: April 17, 2006 - 07:57:59 PM »
Offline Grancoupe
Re: 383 stroker
« Reply #2 on: April 18, 2006 - 04:32:15 PM »
Nice stuff. Are you considering going with one of those motors?
Offline Plum6Pak
  • Plum6Pak
Re: 383 stroker
« Reply #3 on: April 18, 2006 - 05:14:05 PM »
As much as I do like the 383, the one I have is all rebuilt and ready to go but it's either going in the barn for later project or on the market. I have a 500 stroker that's already completed and going into the engine bay soon. You can just about make anything scream like a cat with turpintine on it's rear but I guess it just depends on what you want or already have to build. That 383 stroker would be a torque maker for sure!   :grinyes:
Offline Follicly Challenged
Re: 383 stroker
« Reply #4 on: April 18, 2006 - 06:05:14 PM »
Low Deck 383/400 block based strokers are neat engines ! The 400 block at a common bore 3.75" using same 2.200" Cheb journal and 4.250 stroke is better yet @ 510 Inch.
Offline jc777
Re: 383 stroker
« Reply #5 on: April 19, 2006 - 12:28:04 PM »
I was thinking the new edelbrock victor heads would go great with this motor, but i dont know if i wanna get rid of the 340 just yet..... :grinno:
73' Cuda 340
68' Charger
Offline Grancoupe
Re: 383 stroker
« Reply #6 on: April 19, 2006 - 02:06:10 PM »
Curious about weight. If the 383 would be a good alternative to running a big block but having the weight of a small block. Nothing against small blocks...I have high hopes of eventually putting a Paxton or similar on my 383 to make up for the size difference. SOME of the imports are making some big power numbers with forced induction.
Offline wart1de
    • Vivah
Re: 383 stroker
« Reply #7 on: April 19, 2006 - 05:48:49 PM »
I would of thought a 383 would be pretty much the same weight as a 440.
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Re: 383 stroker
« Reply #8 on: April 20, 2006 - 01:33:58 AM »
383 is only about 40 lbs lighter than the 440 , alum heads help too though
Offline Grancoupe
Re: 383 stroker
« Reply #9 on: April 20, 2006 - 01:47:44 PM »
And a small block is about 140 lbs lighter than a 440, correct?
Offline rallyechall
