Author Topic: Traction Bars: Pros and Cons  (Read 5320 times)
Offline 70 rtse
Re: Traction Bars: Pros and Cons
« Reply #15 on: April 19, 2006 - 06:10:53 AM »
I also have traction bars on my car i need to bring the car back to original how do i do this and what do i need? :feedback:
Offline ShelbyDogg
« Reply #16 on: April 19, 2006 - 01:05:54 PM »
If you have the Good ones, you need to find  a left and right spring perch. That is the piece that mounts the rear end's U-bolts and holds the bottom of the shock. It is the plate right under the rear end tube, unless you have a sway bar plate. If you have the cheap ones, that go under that plate, you just remove them.
Offline Grancoupe
Offline GreenFish
« Reply #18 on: April 21, 2006 - 06:05:46 AM »
Hey 4cruzin...  nice rear end!    :roflsmiley: :bigsmile:
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
« Reply #19 on: April 21, 2006 - 07:28:23 AM »
Those competition engineering bars look pretty sweet, but I don't think they make those for ebodies yet do they?  I couldn't find it on their site, and the article only mentions a- and b-bodies I think.
The only potential drawback I can think of is that I don't know if we can still mount a rear swaybar with that plate.
If it'll work for our setup, I'll bet we get the best traction with those!
Offline tactransman
« Reply #20 on: April 21, 2006 - 11:49:05 AM »
I was wondering if  the CE bars were made for Challengers too. You don't see them advertised any where. :clueless:
Terry-tactransman
Union, Mo.
Offline Grancoupe
« Reply #21 on: April 21, 2006 - 07:03:36 PM »
I don't think that it should make a difference between Cuda's and Challengers. They're both ebodies. The rear frame sections couldn't be that different. I'm going to look around and see if they will fit e-bodies in general. Will post if I find something.
