As long as the carb-intake-cam setup is a good one, it looks like the only option is a different hood, which is too bad. I don't think the drop-base air filters will work because the Holley 750dp has fuel bowls (or whatever they're called) on each side, level with the flange, which I'm guessing would prevent it from dropping (hopefully I'm wrong). Even if I'm wrong, wouldn't it interfere with the linkages?
By the way, K&N had some formulas to calculate the minimum size air filter, and recommend going with a larger diameter and smaller height, instead of smaller diameter and larger height. For an unbored 440 with the highest horsepower at 5500 or 6500 rpm's and a 14" diameter filter, the minimum recommended height is 3.4" or 3.9", respectively.
I'm guessing I should go with a K&N 14" diameter x 4" tall filter, and find a hood that'll work, hopefully the 440 6-pack hood. My only hesitation there is I put a fiberglass hood with a scoop and 4 pins on my other Cuda, and it lifted violently at highway speeds, so I'm not sure fiberglass is the way to go, but metal hoods seem impossible to find. Any ideas are greatly appreciated. Thanks.
