Author Topic: Are you still running your amp guage?  (Read 7669 times)
Offline budrinker
Re: Are you still running your amp guage?
« Reply #30 on: June 04, 2006 - 04:52:33 PM »
looking at these two diagrams i notice they connect the red and black wires together at the fusible link near the battery then run a new wire to the alt    would not connecting the red and black at the link  cause the no spark at the distributor situation
Offline budrinker
« Reply #31 on: June 05, 2006 - 04:07:12 PM »
did the wire fix and bypassed the ammeter  still no spark turns over coil shows power  ????? arrrghh
« Reply #32 on: June 05, 2006 - 04:14:35 PM »
By this, do you mean with the key in the "on" position, you measure 9-10 volts on the "+" side of the coil? If so, that is good news. The only thing I could think of if that is the case is that the electronic ignition box quit on you. Still, what caused all this to begin with?   :clueless:
  ike
« Reply #33 on: June 05, 2006 - 04:17:42 PM »
CHECK IF YOU ARE GETTING POWER UP TO THE BALLAST RESISTOR, IF NOT HAVE TO SEE WHY NOT IF SO CAN START ELIMINATION OF IGNITION ITEMS.
CHECK FOR BURNED WIRES AT THE STEERING COLUMN PLUG ALSO.
Offline budrinker
« Reply #34 on: June 05, 2006 - 04:52:44 PM »
well what started this was smoke and a burning smell at the ammeter if you mean what caused it to blow it looked like it was very poorly installed.......... and grounded it self out     im sure i did the bypass correctly but it has no spark at the coil  ill take it apart and try agian    god i hate electrical problems
Offline budrinker
« Reply #35 on: June 06, 2006 - 08:14:27 PM »
well did the whole new ammeter bypass over again  went through the bulk head cleaned and greased  checked all wires for damage they all had some  but they did b4 the melt down :(   still no spark   is it possible for the ammeter failure fried another component in the ignition set ???     im gonna try the coil clip hot wire test in the am  anyone with any clues ??
