Author Topic: radiator coolant recovery  (Read 5761 times)
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« on: April 24, 2006 - 11:29:39 PM »
My car does not seem to run hot (according to the gauge), but always seems to leave a small 1''- 2'' puddle on the floor after a putt around the neigborhood.
Questions:
1. did 1970 Challengers (440-6V) come with coolant recovery systems stock?
2. if so, any pics out there?
3. if not, how many of you add 'em? and where'd ya get 'em?
Thanks
Eric
« Last Edit: April 25, 2006 - 11:32:38 PM by chevyconvert »
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Re: radiator coolant recovery
« Reply #1 on: April 25, 2006 - 12:17:38 AM »
nothing from the factory
water wetter can help with heat transfer but basically don`t overfill it , it should have a bar visable under the filler neck , that is the max fill  line
Offline GoodysGotaCuda
« Reply #2 on: April 25, 2006 - 02:22:34 AM »
My car does not seem to run hot (according to the gauge), but always seems to have a leave a small 1''- 2'' puddle on the floor after a putt around the neigborhood.
Questions:
Thanks
Eric
How 'factory' is it under the hood? Are you looking for something stock, or would something aftermarket do the trick. As you can see, mines not very 'factory'  :lol: I have a Moroso recovery tank that holds a quart of fluid mounted next to the passenger side radiator tank. Pretty much out of sight unless you are looking for it. It does recover the fluid that is spit out of the radiator, as the radiator starts cooling back off it will suck what it spit out back in there  :cooldancing:
Hope it helps some.
-Mike
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline falcon50flier
« Reply #3 on: April 25, 2006 - 08:06:01 PM »
Your cap may not be sealing properly, allowing coolant to push up into the overflow nipple before the system even gets to operating pressure.
Option - lose the squirters and convert your washer bottle to a coolant recovery tank.
Air in the cooling system from keeping the upper tank less than full to the neck costs coolant capacity and can reduce cooling system performance. "Closed systems" were introduced in GM cars in the late 60s to improve cooling performance on air conditioned models, and although I think these were all crossflow applications, it still makes the system more efficient.
70 Challenger convertible
518 cid Hemi, TF727, 3.73 Dana 60
  • HvacMan
« Reply #4 on: April 25, 2006 - 11:38:39 PM »
Converting the washer bottle is an interesting idea...not using it now. What modifications would I have to do to make it work?
 Does the hose have to go to the bottom of the reservoir?
How air tight does the tank need to be?
Thanks
Eric
Eric
Bay Area California
« Reply #5 on: April 25, 2006 - 11:44:14 PM »
to work correctly the hose should either reach the bottom of the tank or be tapped into the bottom , the tank doesn`t need to be airtight
« Reply #6 on: April 26, 2006 - 12:01:29 AM »
It actually should have some source of venting. My Moroso tank came with a small hole in the top for venting. Converting the washer bottle should be pretty easy.
My car came with a original overflow tank as you can see on the left. My washer bottle isn't in, in that picture there. It just basically needs the hole in the bottom to attach a hose to, that feeds to the radiator.
1976 Dodge Warlock
  • HvacMan
« Reply #7 on: April 26, 2006 - 12:06:26 AM »
ok..oh yeah does it use a different type of rad cap? Presure rating?
Eric
Bay Area California
« Reply #8 on: April 26, 2006 - 12:14:05 AM »
16 psi with the ability to open & suck fluid back in as it cools & contracts
« Reply #9 on: April 26, 2006 - 07:13:59 PM »
As the posts above acknowledge, the washer bottle is perfect as a recovery/closed system coolant tank:
1) bottom nipple places coolant "head" on line to overflow nipple on tank neck, always keep bottle 1/4 full minimum.
2) 1/4" ID hose is a snug fit on both ends.
3) snap cap vents bottle, drill a small hole if yours doesn't have a one (some repops)
4) ample reservoir capacity for coolant system
5) best of all, it already mounts in the ideal spot!
I run a Totally Auto repop bottle, they make clear/white and yellow/aged versions. Note - I found the small amount of flashing on the bottom nipple from the mold parting line was enough to cause a micro-leak from the hose. A tough leak to chase down, but my suspicions were confirmed. She's liquid tight now..
Offline ShelbyDogg
« Reply #10 on: April 26, 2006 - 10:49:46 PM »
Here's mine in front of the battery.     Mopars always puke even with a properly working cooling system. Expansion has to go somewhere.
« Last Edit: May 23, 2006 - 03:13:08 PM by Rev-It-Up »
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
« Reply #11 on: April 27, 2006 - 04:19:40 AM »
I had an ugly aftermarket bottle mounted to the front of the core support. Looked bad so I found this.  From the front all you can see is the cap and it's 16 inches long and stainless. Interesting design, hose connector and vent come out the bottom, hidden
« Reply #12 on: April 27, 2006 - 03:57:34 PM »
Heres my moroso  :thumbsup:
1976 Dodge Warlock
  • HvacMan
« Reply #13 on: April 28, 2006 - 11:53:47 PM »
Remember brand and where you got it?
Eric
Bay Area California
« Reply #14 on: April 29, 2006 - 04:18:36 AM »
