Author Topic: Fuel tank wiring  (Read 1912 times)
Offline tman
Fuel tank wiring
« on: April 25, 2006 - 03:46:02 AM »
Just purchased a 70 440-6 Cuda.  It was restored about 3 yrs ago.  The tank looks new.  The problem Im having is the fuel guage is stuck at "F" (full). It does not move.  I hope the problem is a missing Ground strap or clip.  Based on Service manual, there is suppose be a ground clip.  The diagram is not very good.  Anyone have experience with the wiring?  Any tips would help.  Thanks all!
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
Re: Fuel tank wiring
« Reply #1 on: April 25, 2006 - 06:38:53 AM »
sender is stuck in the up postion as no ground would give you no reading at all!
« Reply #2 on: April 25, 2006 - 07:15:46 AM »
Maybe somehow the blue wire that goes to the sending unit is shorting to ground? Also, if this is an old original sending unit, it's easy to short the strap to the pick-up tube inside the gas tank.
